dreamer Posted July 3, 2010 Share Posted July 3, 2010 Hi This is only an example. Lines and arcs as seen are on different UCS planes, I want to join them and make it a path for the circle to SWEEP along. But how to join them together? At the moment they are in 4 sections. Thanks. Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 3, 2010 Share Posted July 3, 2010 Please check those threads: http://www.cadtutor.net/forum/showthread.php?t=14259 http://www.cadtutor.net/forum/showthread.php?t=48640 Regards, Quote Link to comment Share on other sites More sharing options...
dreamer Posted July 3, 2010 Author Share Posted July 3, 2010 msasu But that was the old method before SWEEP time. I thought there is a quicker method these days. Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 3, 2010 Share Posted July 3, 2010 Even if you use Rotate3D to align the section to be extruded on path followed by EXTRUDE or use SWEEP, the idea on recommended threads is to generate separate parts on exiting paths and join them together. Regards, Quote Link to comment Share on other sites More sharing options...
dreamer Posted July 3, 2010 Author Share Posted July 3, 2010 Thanks msasu. AutoCAD has enhanced so many Commands all these years. I am surprised that joining lines on different ucs planes still an impossible task. Regards Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 3, 2010 Share Posted July 3, 2010 Thanks msasu.AutoCAD has enhanced so many Commands all these years. I am surprised that joining lines on different ucs planes still an impossible task. Regards Autodesk Inventor. (actually Inventor doesn't even fool with a polyline type - Inventor sees them as connected sweep path). Quote Link to comment Share on other sites More sharing options...
