Boundary Creation Lisp- a request
onzki
Hi, I am doing a work that prompts me to use boundary creation often so I would like to request for Boundary creation LISP. The normal process (AutoCad 2007) when I typed in a command for boundary or "bo"-
1. Type boundary or BO at command line
2. the dialogue box comes out,
3. Pick a point button,
4. pick a point at the drawing,
5. Hit enter to end.
Now is there a way to shortcut this, like I will need to do steps #1 and #4 only and skip others?
Thanks a lot! :)
Use -Boundary.
Thanks, I didn't know that before (-boundary). I'm not yet familiar with macros so I just assigned my -boundary command alias to "bo". Thanks again :)
@Tharwat313:
Thanks for the code, I liked that one-its "quick and quiet" :) By the way- If I may inquire further- right now, what we have is one by one selection. However, is it possible to redefine this command by clicking continuously or having multiple points selection? What I mean is, after the command- I can click one or more points and when I'm done, I can simple hit enter to end.
I attached an image for reference. The numbering inside is just an assumed point selection sequence for boundary creation.
Thanks! :)
Uploaded with ImageShack.us
Hi
I guess this would be the best for your needs .... check this out.
Enjoy.....
(defun c:gift (/ num)
(setq num (getint"\nEnter number of boundary Frames:"))
 (repeat num
 (command "_.-boundary" pause "")
Best regards.
Tharwat
A while statement would be what you want...
(defun c:BND (/ pt)
 (while (setq pt (getpoint "\nPick internal point: "))
   (command "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "")
hi,,, wow,,, exactly what i needed,, but guys can this be stretch further by remembering the created boundary in a selection set and then at the end of the "boundary" session command it will invoke the "hatch" command and since you already have the selection set earlier it will use that selection for the hatch boundary,,,thanks in advance
Hi,
no need for a selection set, entlast will do it:
(defun c:BND (/ pt)
[color=Blue](command "_hatch" "solid" (entlast) "")[/color]
BTW: the "bhatch-command" has an option which allow you to create a hatch and keep the boundary polyline.
regards
Wolfgang
Hi
This is how it should be .
(defun c:BND (/ pt)
(command "_.-hatch" "_p" "_solid" pt "")
Regards
Tharwat
Hi
Now this is becoming more interesting, "stretchable" as well as challenging :). Aside from hatching, is it also possible to evoke an "Area" computation (metric- M²) command instead of hatch. This time, automatically creating a text value (of readable height) on center of each polygon.. and finally assigning a layer "AREA" to both polygon and area text.
Sorry if I requested too much. I'm just overwhelmed. I know you are not magicians haha :D .. but if it is possible, I'm sure it'll be beneficial to everyone.
Up late packing for camping/hiking trip. Thought I'd take a break, saw this and decided to post a quickie...
Enjoy and see you guys on Monday. I'm off to the woods at first light.
(defun c:HatL (/ foo eLast pt obj)
 ;; Alan J. Thompson, 07.09.10
 (vl-load-com)
 (defun foo (o / a b)
   (vla-getboundingbox o 'a 'b)
   (mapcar '(lambda (a b) (/ (+ a b) 2.)) (vlax-safearray->list a) (vlax-safearray->list b))
 (setq eLast (entlast))
 (if (and (setq pt (getpoint "\nSpecify point within area to hatch and label: "))
          (vl-cmdf "_.-bhatch" "_non" pt "SOLID" "_A" "_R" "_Y" "" "")
          (not (equal eLast (setq obj (entlast))))
          (setq obj (vlax-ename->vla-object obj))
   (vla-put-BackgroundFill
     (AT:MText (foo obj)
               (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                       (itoa (vla-get-objectid obj))
                       ">%).Area \\f \"%lu6%qf1\">%"
               0.
               nil
               5
     :vlax-true
(defun AT:MText (Pt Str Wd Lay Jus / Wd s o)
 ;; Add MText to drawing
 ;; Pt - MText insertion point
 ;; Str - String to place in created MText object
 ;; Wd - Width of MText object (if nil, will be 0 width)
 ;; Lay - Layer to place Mtext object on (nil for current)
 ;; Jus - Justification # for Mtext object
 ;;       1 or nil= TopLeft
 ;;       2= TopCenter
 ;;       3= TopRight
 ;;       4= MiddleLeft
 ;;       5= MiddleCenter
 ;;       6= MiddleRight
 ;;       7= BottomLeft
 ;;       8= BottomCenter
 ;;       9= BottomRight
 ;; Alan J. Thompson, 05.23.09 / 04.09.10
 (or Wd (setq Wd 0.))
 (setq s  (if (or (eq acmodelspace
                      (vla-get-activespace
                        (cond (*AcadDoc*)
                              ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
                  (eq :vlax-true (vla-get-mspace *AcadDoc*))
            (vla-get-modelspace *AcadDoc*)
            (vla-get-paperspace *AcadDoc*)
       Pt (cond ((vl-consp Pt) (vlax-3d-point Pt))
                ((eq (type Pt) 'variant) Pt)
 (vla-put-lock (vlax-ename->vla-object (tblobjname "layer" (getvar 'clayer))) :vlax-false)
 (setq o (vla-addMText s Pt Wd (vl-princ-to-string Str)))
 (and Lay (tblsearch "layer" Lay) (vla-put-layer o Lay))
 (cond ((vl-position Jus '(1 2 3 4 5 6 7 8 9))
        (vla-put-AttachmentPoint o Jus)
        (vla-put-InsertionPoint o Pt)
 o
(defun c:BND (/ pt)
@Allanjt: In case I want the original lines to be deleted afterwards so that only the new closed polyline/boundary remains, what would I add to this lisp?
Thanks!
Thanks!
If that's all your wanting to accomplish, just select everything and convert them to a polyline with PEdit.
  • 3 years later...
Hi,
Excellent code, guys!!!
I'd like to delete the hatch in the code.
Anybody Can help me please?
Thank in advance
Edited by Madruga_SP
