Bobzy20 Posted July 6, 2010 Share Posted July 6, 2010 I’m trying to make my AutoCAD object (1st image below) look like the 2nd object below but seem to be having trouble. I’m trying to Subtract the Loft (Red area) from the Solid body but I cant get it to work. Please see the link below to download my CAD drawing: http://modelbuild.co.uk/PG_HOUSING.zip It was over 250kb. Thanks Bobzy20 Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 6, 2010 Share Posted July 6, 2010 It appears that a portion of your model is made up of surfaces and not solids. Is that correct? I got this error when trying to do the subtraction: The Boolean operation on solid and/or surface bodies failed. Modeling Operation Error: System inconsistency processing edge coincidence. You too? Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted July 6, 2010 Author Share Posted July 6, 2010 Hi yes the Loft on Layer: "PG_LOFT_1" is a SURFACE but all the rest are 3D SOLIDS. I guess you can’t subtract surfaces from solids or vice-versa? Quote Link to comment Share on other sites More sharing options...
dtaylor Posted July 6, 2010 Share Posted July 6, 2010 so i exploded the surface then converted the splines into 3d polylines. When I attempt to loft those two polylines into a 3d object Autocad hangs. My comp might not be powerful enough, but i'd try that so you can add and subtract Quote Link to comment Share on other sites More sharing options...
dtaylor Posted July 6, 2010 Share Posted July 6, 2010 so autocad just unhung itself and it made a sort of ugly 3d solid Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 6, 2010 Share Posted July 6, 2010 I don't see any portion of your surface that a subtraction could be done on because you already have a "hole" where the object you are trying to subtract sits. You cannot subtract PG_Loft_2 from PG_Loft_1 as far as I can tell. You can however subtract a portion of PG_Loft_2 from PG_Housing_Top. Quote Link to comment Share on other sites More sharing options...
dtaylor Posted July 6, 2010 Share Posted July 6, 2010 it ended up not making a 3d solid, just a really detailed cpu intensive surface Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 6, 2010 Share Posted July 6, 2010 I tried that same trick (loft upper and lower portions of surface) but got a message saying the objects were not planar. I know for sure the top one is so I'm inclined to say it is the bottom one that caused the command to fail. Quote Link to comment Share on other sites More sharing options...
dtaylor Posted July 6, 2010 Share Posted July 6, 2010 ya, the bottom is a 3d polyline. im about to try to make some surfaces and then see if i can make a 3d solid Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 6, 2010 Share Posted July 6, 2010 I used Splinedit and it converted the top line to a polyline (planar) and the bottom one to a LWpolyline (non-planar). It would not let me do a loft between the two. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted July 6, 2010 Share Posted July 6, 2010 Your best bet in this case is to forget about the surface. Draw the "hump" as a solid loft. Then extrude/subtract the opening with a draft. There is a lisp here that will convert a surface to a solid. its called mesh2solid or m2s. If you want to use surfaces then look into the Slice command. It should let you slice a solid with a surface. Quote Link to comment Share on other sites More sharing options...
rvpas Posted July 6, 2010 Share Posted July 6, 2010 Hi Bobzy20, I found a trick by using the new commands of tools surface. 1- Patch to create surface on top and bottom Surface tab/Surfaces/Patch 2- Surfextend to extend surface on top an bottom because the surface of the outline has to exceed the surface of the top and the bottom to be able to use sculpt Surface tab/Surface editing/Extend 3- Surfsculpt to create a solid Surface tab/Surface editing/Sculpt 4- Loft to create solid to use to substract Home tab/Modeling/Loft 5- Substract I cant attached file because is to big see link below http://www.cijoint.fr/cj201007/cijFUvb8Lu.zip Thank you for this "brain teaser" because grace to you I saw a real application of the new commands of tools surfaces. By hoping to have been rather explicit Have a good day Pascal PS : If link dont work send me an email. Quote Link to comment Share on other sites More sharing options...
