+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Forum Newbie
    Using
    not specified
    Join Date
    Dec 2005
    Posts
    2
    Default Fillet round edge?
    im using AutoCAD 2006
    i need to fillet this round edge
    How?
    http://www.megaupload.com/?d=V0PBW6ZE
  2. #2
    Bloodwig80
    Default
    uhh. i looked at it but i dont know what the edges lead to. do they end abruptly or do they blend into another surface? or is this object simply shaped like a bar of soap? dunno.
    oh yeah use www.yousendit.com for uploads. megaupload makes u wait 60 seconds before download and bombards you with pop-ups
  3. #3
    Senior Member
    Using
    not specified
    Join Date
    Oct 2005
    Location
    UK
    Posts
    156
    Default
    If what you've drawn is a solid, try the fillet command with the 'chain' option.
    If what you've drawn isn't a solid: Draw it as a solid
    Aled Taylor
    (File size is someone else's problem)
  4. #4
    Forum Newbie
    Using
    not specified
    Join Date
    Dec 2005
    Posts
    2
    Default
    thnx i used fillet chain and it worked.........
Posting Permissions
  • You may not post replies
  • You may not edit your posts
