MeOH Posted July 9, 2010 Share Posted July 9, 2010 I open up the text dialog box and select a new font (arch.) and the text does not change font at all. I can change the height. Do I need to pull a text file from an older version of autocad that I was previously using and drop it into a 2011 text folder? Quote Link to comment Share on other sites More sharing options...
rkent Posted July 9, 2010 Share Posted July 9, 2010 Are you dealing with MText objects? If so then the font style has been overridden in the mtext definition. Pick on one that won't update and open Properties, in the content box you will see some coding in front of the text that is displayed on screen. If this is the problem then you can use a lisp file to strip the formating off of the mtext. The one attached was not made by myself. stripmtext.zip Quote Link to comment Share on other sites More sharing options...
