Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2008
    Jul 2010
    2
    Default Grouping Problem.
    On AutoCAD 2006 , at work in my office, I wish to group some entities. At home I use AutoCAD LT which involves selecting GROUP from a task window, selecting entitities and tapping complete. They are then grouped and I can jerk them around at will. Happy me.At the office however, I must begin by typing "Group" as a command and am then given a window to give the desired group a name and select other characteristics for it. I have applied all possible combinations of choices for what I might want, have selected the entities for the group and answered as affirmitively as options allow that what I have indicated is what I want and can get a response from the cursor that the entities are a group . . . UNTIL I TRY TO DO SOMETHING WITH THE GROUP. It behaves as if it weren't grouped.i.e., the whole thing lights up as if it were a group but I can only manipulate one piece of itWould someone be kind enough to give me a simple human algorithm for grouping entities in AutoCAD 2006? I mean somethingthing really simple that will allow for no other outcome than grouping, seeing the indication of groupness, and being able to move, rotate or whatever the grouped thing as a whole.I do not need to know how to ungroup, add or subtract from the group.I moved things that I had successfully grouped in the past to another file in order to ungroup them. That I had successfully grouped in the past (six months or so) leads me to think that I have inserted a command into the general system to indicate success in a grouping endeavor but then ignore the effects of having done so.This is my first post on this B Log so bear with me regarding my replies to anyone offering assistance.Gordon Knight
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    to make a long story short...
    Try Ctrl+H (or Pickstyle=1 or 3)
    Forum Newbie
    AutoCAD 2008
    Jul 2010
    2
    To lengthen a short reply . . On a field with two objects to group I did Ctrl+H and was instructed to enter a new value for pickstyle. All attempts to enter anything got nothing but "invalid command"
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Pickstyle controls the use of group selection (look in Help). Ctrl+H toggles Pickstyle.
    Hit Ctrl+H, then try and select an existing group. Hit Ctrl+H and again try and select the group.
  5. #5
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    to make a short answer even longer - here's a tutorial I wrote:
    http://thecadsetterout.wordpress.com...your-geometry/
  1. Problems with Grouping
    By NiceGuy8618 in forum AutoCAD Beginners' Area
    Last Post: 19th Jul 2008, 12:48 am
  2. Object grouping
    By Lyp in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jan 2008, 06:22 pm
  3. Grouping in Drawings
    By shyguy in forum AutoCAD General
    Last Post: 26th Oct 2007, 12:44 am
  4. COUNTING? GROUPING?
    By fade2blackened in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2006, 05:09 pm
  5. grouping objects
    By lorenzo in forum AutoCAD Beginners' Area
    Last Post: 13th Dec 2002, 02:34 am
