ko31505 Posted July 15, 2010 Share Posted July 15, 2010 As I create rungs with the default numbers 741 -whichever by usign the default rung numbers I cannot add rungs I click on the ladder using the "ADD rungs" and if the numbering stops at 753 I will not put a 754 rung on the current ladder. Is there a way to do this? the book I am using seems to claim so. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 19, 2010 Share Posted July 19, 2010 You're using the Add Rung tool to add rungs between the vertical rails of a ladder correct? How are you picking the insertion point? Quote Link to comment Share on other sites More sharing options...
ko31505 Posted August 4, 2010 Author Share Posted August 4, 2010 What I really want to do is add one in between existing rungs and have the rest of the rungs just move down one at the bottom. Is this possible? thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 4, 2010 Share Posted August 4, 2010 I think you need to use the Revise Ladder tool to add a rung. Quote Link to comment Share on other sites More sharing options...
firsrate_caduser Posted January 19, 2011 Share Posted January 19, 2011 I hope this would do what you want. You can add rungs by clicking the first number of the rung and right click on it and chose edit component. A sub window would appear and in there you would be able to modify the spacing and rung count and reference start number of the ladder diagram. I know this would effect the whole ladder diagram. let me know if this solve you problem. Quote Link to comment Share on other sites More sharing options...
