Results 1 to 8 of 8
    Super Member Lt Dan's legs's Avatar
    AutoCAD 2007
    May 2010
    Florida
    574
    Default Menu while command is active
    How do you offer options while still having the command active? How about displaying current settings?
    example:
    Code:
    Command: ML
    Current settings: Justification = Zero, Scale = 1.00, Style = BWALL
    Specify start point or [Justification/Scale/STyle]:
    Autolisp response please
    AutoCAD 2007
    May 2010
    Florida
    574
    Quote Originally Posted by Lt Dan's legs View Post
    example:
    Code:
    Command: ML
    I found the first part.
    Code:
    menucmd
    still wondering about the settings display
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    No need for menucmd.
    All the GetXXX functions will honour keywords - use initget.
    As for the current settings, just use a princ call.
    Lee Mac Programming
    Just another Swamper
    AutoCAD 2007
    May 2010
    Florida
    574
    Quote Originally Posted by Lee Mac View Post
    When I put in menucmd I was looking at the old dline lisp. I thought I figured it out but by the time I realized it wasn't it you answered my question.
    I thought there was a different way of doing princ call but seems like this is the best way.
    Thank you
  5. #5
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,050
    Except getstring, for obvious reasons.
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  6. #6
    AutoCAD 2007
    May 2010
    Florida
    574
    I got my program to work the way I wanted. Many thanks Lee!
    one more question
    Code:
    (setq wait t)
    (while wait ...
    Will this only work for while or is there other commands I can use this with?
    ___
    I had problems with
    Code:
    (progn wait
    ...Maybe the routine had errors
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    one more question
    Code:
    (setq wait t)
    (while wait ...
    ___
    I had problems with
    Code:
    (progn wait
    I don't know what you mean?
    Lee Mac Programming
  8. #8
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    Do you need a form that shows all the current settings and if correct press Ok else pick box and change this could be written as a seperate defun and just called as a step at the start of your program.
    Or princ all the results as per Lee Mac and just press enter if ok, any other key would mean change this is pretty quick in a program and you dont need to code a dcl if in lisp. I use this enter method a lot very easy for everyone to use at our work.
    Code:
    (princ "all your values here")
    (setq ans (getstring ans "\nIf values ok press <Cr> else any key"))
    (IF (= ans NIL)
    (setnewvals)
    (defun newvals ()
    (princ styleval)
    (IF (= ans NIL)
    (setq styleval (Getstring "\nEnter new style name"))
    (setvar "stylname" stylname)   ; I can nor rember style variable
    just repeat for all other vaules may mean you press Cr Cr enter val Cr Cr etc
    Hopes this may be of use
  1. Layer Control while command active
    By qball in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Feb 2009, 10:07 pm
  2. Menu Command
    By J_Melcher in forum AutoCAD Beginners' Area
    Last Post: 16th Dec 2008, 04:00 pm
  3. Stopping an active command in VB.Net
    By bsamc2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Jan 2008, 07:25 pm
  4. keeping the same command active without having to keep retyping it
    By Brian in forum AutoCAD Drawing Management & Output
    Last Post: 1st Nov 2007, 01:05 pm
  5. HOW TO CANCEL ACTIVE COMMAND USING VB
    By supils in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2005, 11:38 am
