iffat150 Posted July 16, 2010 Share Posted July 16, 2010 does anyone know how to put degree symbol using slant leroy mono font. i was using %%D but it is not working for this kind of font. it is coming as 33/64. thanks in advance. Quote Link to comment Share on other sites More sharing options...
eldon Posted July 16, 2010 Share Posted July 16, 2010 Is this font SHX or TTF? If a TTF then have you explored the Character map? I am not familiar with this font, so if it is a special one and you solve how to show the degrees symbol, then if you send this drawing to somewhere else, are you going to send the font with it? otherwise they will not be able to read text properly. You must be aware of the portability of data. Quote Link to comment Share on other sites More sharing options...
iffat150 Posted July 16, 2010 Author Share Posted July 16, 2010 this is a SHX font. i even used \U+00B0 command and still it is giving me same result (33/64). hope someone very expert will help me out of this trouble soon....... Quote Link to comment Share on other sites More sharing options...
eldon Posted July 18, 2010 Share Posted July 18, 2010 The first thing that I would do is to de-compile the shx file to give a shp file, and you can then see what is going on. You have to use the DUMPSHX programme from the OS command line, and that is in Express Tools. Have you also tried the key combination Alt 0176 to give ° Quote Link to comment Share on other sites More sharing options...
iffat150 Posted July 20, 2010 Author Share Posted July 20, 2010 (shift + 6) combination worked. thank you Eldon for your help. Quote Link to comment Share on other sites More sharing options...
cadvision Posted July 26, 2010 Share Posted July 26, 2010 trouble with using shift+6 is if the file goes to someone else and they don't have the font it will remap and you will get ^ instead. Had that in the past. Quote Link to comment Share on other sites More sharing options...
