pharrold Posted July 19, 2010 Share Posted July 19, 2010 Hi, I have a script that will plot layers automatically without me going into layer manager and changing them and then clicking plot. The drawings i will be working with are electrical, they have many layers in one drawing. the layers are not sequentially numbered so makes the script harder to produce. In theory i wanted a vB program were i have check boxes of the layeers and then the layers checked are pasted into the script. Has anyone got any ideas? the script is as follows: ;BEGIN SCRIPT ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 002 002 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 002 002 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 003 003 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 003 003 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 005 005 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 005 005 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 006 006 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 006 006 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 010 010 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 010 010 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 012 012 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 012 012 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 013 013 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 013 013 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 014 014 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 014 014 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 015 015 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 015 015 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 016 016 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 016 016 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 017 017 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 017 017 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 018 018 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 018 018 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 019 019 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 019 019 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;Command: useri1 USERI1 ;Enter new value for USERI1 : 021 021 ;Command: -layer -LAYER ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: S ;Enter layer name to make current or : 021 021 ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: F ;Enter name list of layer(s) to freeze or : * * ;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]: T ;Enter name list of layer(s) to thaw: 0 0 ;Command: -plot -PLOT ;Detailed plot configuration? [Yes/No] : ;Enter a layout name or [?] : ;Enter a page setup name : ;Enter an output device name or [?] : ;Write the plot to a file [Yes/No] : ;Save changes to page setup [Yes/No]? ;Proceed with plot [Yes/No] : ;END SCRIPT Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 21, 2010 Share Posted July 21, 2010 I would write a vba or lisp a simple 1 would be just step through the layer table and answer y or n then it would write a script answer to turn off the unwanted. You could populate a list with layer names and have a remove/add button as you pick in a dcl or form then press ok to finish. You can also create layer groups and save, say all currently "on" within the normal layer manager. Also current layer 1 line (setvar "clayer" 019) this is ok in scripts even though its lisp Quote Link to comment Share on other sites More sharing options...
