Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    AutoCAD 2008
    Jun 2010
    10
    Default plotting to pdf issues
    Hello all, hoping you can help me with a current issue I am having. I have a rather large floorplan (2D) I am trying to convert to pdf format in Autocad 2008. I am able to make the conversion through the plot command, but the lines and text in the pdf drawing are not distinct enough (i.e. line weight is too large???). I have tried selecting all objects in the dwg file to change the line weight through properties, but unable to do so. The program seems to lock up selecting that many objects.
    Any advise/help on converting dwg to a "crisp" pdf file would be appreciated.
    thanks,
    Super Member Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Independent Architectural Draftsman
    Construction
    Residential Homes, Construction and Renovation
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,770
    This one should be a FAQ. It comes up all the time.
    I have a similar issue with AutoCAD LT 2009. Some text also appears to be BOLD and fuzzy, in addition to the messed up line weights.
    Go to AutoDesk website and download the FREE TrueView 2010 or 2011 whichever is available. Open your drawing with TrueView and plot as usual. It does a fine job of plotting pdf files.
    TrueView can also convert newer drawing versions to older ones so your AutoCAD 2008 can open them.
    Did I mention it was FREE?
    Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
    Full Member Skybeorn's Avatar
    Skybeorn's Computer Details
    Windows 7
    Asus G60vx
    Intel Core 2 Duo P7450 / 2.13 GHz ( Dual-Core )
    4 GB
    NVIDIA GeForce GTX 260M
    320 GB - Serial ATA-150 - 7200 rpm
    Dell 22" LCD + Laptop
    AutoCAD 2009
    Jun 2010
    Wisconsin
    43
    Did you check The plotting Lineweight? (In the layer properties Manager)
    Also look in the print dialog optins to make sure you are not plotting lineweights.
    *_* Skybeorn *_*
    Junior Member
    AutoCAD 2008
    Jun 2010
    10
    Dana - True view software may/may not be a viable option for my concern. I am using Autocad at work and will have to speak with some people in IT to see if they will authorize the download. But I will persue that.
    I am not able to follow the paths that Sky... suggests. Are they for another version? We presently use Autocad 2008.
    thanks
  5. #5
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    You don't need to download DWG Trueview. The only reason it works better is that the built in "DWG to PDF" driver was much improved starting with the 2010 version of AutoCAD (and therefore DWG Trueview).
    So, it's pretty much universally agreed that the 2007-2009 versions of this PDF driver in AutoCAD were not that good (as you are seeing)... However that may not even be your issue. Are you using plot styles or relying on the lineweights assigned to the entities in the drawing?
    If you would just like to try a different PDF driver, you can download one of the free ones like CutePDF and give that a shot also.
  6. #6
    Junior Member
    AutoCAD 2008
    Jun 2010
    10
    To answer your question, I am relying on the lineweights assigned in the drawing.
    Thanks for the info on Trueview, it all makes sense now. I think I will still try to have our system admins OK the download as it would give us other benefits. Presently, the only way we "share" cad drawings internally is converting to pdf. Which limits the ability of non-cad users in contributing their input. From what I am reading on the autodesk web site, the Trueview software will allow them to view the original cad drawing and notate it without having Autocad installed.
  7. #7
    Windows 7
    Asus G60vx
    4 GB
    AutoCAD 2009
    Jun 2010
    Wisconsin
    43
    TJS,
    Check the screenshot. Maybe that will help. (I have 2009)
    As you could just adjust the linweight on one layer in a viewport VS turning them all off. (VP lineweight)
    *_* Skybeorn *_*
  8. #8
    Junior Member
    AutoCAD 2008
    Jun 2010
    10
    Skybeorn,
    Those options are under page set up on my version, 2008. I was able to create aplot style table to designate line wt. when plotting and then access it through the page set up menue. It does sharpen up the object lines when I plot to pdf, but I am not totally happy with the text yet. I will keep trying though.
    I am going to explore the Trueview option that Dana suggested, if our System Admins will ok the download. Will let all know if that helps.
    thanks for the help,
  9. #9
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by tjs1362 View Post
    ... From what I am reading on the autodesk web site, the Trueview software will allow them to view the original cad drawing and notate it without having Autocad installed.
    DWG Trueview is a *viewer* only. You can open, view, and print. That is about it.
    You can markup using "Autodesk Design Review" (ADR), but this program does not read DWG files. (ADR can "import" DWG files, but all it is really doing is printing the DWG to DWF and opening the DWF file.)
  10. #10
    Junior Member
    AutoCAD 2008
    Jun 2010
    10
    Thanks rkmcswain, I will look into both of those freeware programs. Both would be of value to us (although it will take some time to obtain permission from our system administrators).
  1. Plotting Issues
    By BSewell in forum AutoCAD Drawing Management & Output
    Last Post: 18th May 2010, 06:53 pm
  2. 3D Plotting Issues
    By uA667 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Apr 2010, 07:53 pm
  3. plotting issues
    By dragonpace in forum AutoCAD General
    Last Post: 17th Dec 2009, 07:46 pm
  4. Plotting issues
    By KWatkins in forum AutoCAD Beginners' Area
    Last Post: 15th Jul 2009, 09:47 pm
  5. Plotting Issues
    By Hoover in forum AutoCAD Beginners' Area
    Last Post: 22nd Jan 2007, 11:26 pm
