Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Default problem with displacemet or use first point as displacement in copy, move commands
    I have difficulty on specifying the distance for copy or move commands. It has different options and I have to get my desired result after many try and error.
    Where can I find a detailed explanation on these commands options? distance, base point and first point as displacement.
    My exact problem is as follows:
    I want to move a line 5 cm to the right of present location with orthogonal active . What is the best/fastest way to do this?
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    867
    check polar tracking is set to "on" (F10 i think)
    then just:
    enter command "M"
    click the line to select it
    hit enter
    move cursor in the 'right' direction (you will see dotted lines for 'snapable' polar directions if you move around)
    type "5" (or distance required in whatever units you are drawing in)
    Super Member
    xp
    various
    Architectural
    architect
    Architectural
    ADT 2009
    Jun 2010
    867
    i use 2 ways to move / copy ---
    option 1:
    'base point' is where you want to move it from
    'second point' is where you want to move it to
    option 2:
    select base point
    enter distance and direction (i use tracking, but you can specify an angle instead)
    displacement is to move it using coordinates (i don't use this)
    hope this helps!
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,730
    # for absolute (default in earlier releases)
    @ for relative (default in later releases)
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,833
    Another option is to enable Orthomode, invoke the Move or Copy command, pick on the object and drag it in the direction you want to go. At the command line type in your distance and then press the Enter key.
  6. #6
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Quote Originally Posted by designerstuart View Post
    then just:
    enter command "M"
    hit enter
    Thanks. this is what I use exactly but sometimes it doesn't go this way. I think I am confusing with other things or there are many lines and it selects different line.
    One big mistake is when the OSNAP is on and when after selecting the base point, when I move to right for 5 cm, it snaps end of another line and selects it as second point and I have to undo and start again. I think in this situation it is better to turn off the OSNAP.
  7. #7
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    option 1:
    I understand this one and there is no problem
    [QUOTE
    option 2:
    select base point
    [/QUOTE]
    My problem is in this case and when I want to enter the distance in command line, it messes up
    [QUOTE
    [/QUOTE]
    This is want I want to figure out as well
  8. #8
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Thanks. Isn't it same as polar tracking mentioned by designerstuart ?
  9. #9
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Quote Originally Posted by JD Mather View Post
    Thanks. What is case for ACAD 2007?
    In case of relative coordinate, is it measured relative to first point?
  10. #10
    Super Member
    xp
    various
    Architectural
    architect
    Architectural
    ADT 2009
    Jun 2010
    867
    Quote Originally Posted by khoshravan View Post
    almost. orthomode locks into set directions, while polar tracking just 'snaps'
    if there are too many lines, turn osnap on for first point, then off for second point (easy with F5 (i think))
    but using coord there should be no mistakes.... snap will not interfere
  1. Move/Rotate/Copy to Center of a Line
    By ecshclark in forum Autodesk Inventor
    Last Post: 4th Jun 2010, 08:30 pm
  2. Continual crashes caused by copy, past, and move commands
    By looseLISPSsinkSHIPS in forum AutoCAD General
    Last Post: 15th Dec 2009, 02:50 pm
  3. COPY or ** COPY ** - Copy and Stretch, Move, Rotate, Scale & Mirror objects
    By Andrew1979 in forum Tutorials & Tips'n'Tricks
    Last Post: 27th Jul 2009, 07:36 am
  4. how to move origin point ?
    By airs in forum AutoCAD Beginners' Area
    Last Post: 20th Nov 2006, 12:52 am
  5. Copy to Clipboard / Copy with Base Point not working
    By Orbit in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2003, 03:10 am
Tags for this Thread
