+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Forum Newbie
    Using
    not specified
    Join Date
    Dec 2005
    Posts
    2
    Default convert an AutoCAD file to a Microstation file?
    Hi, I am not a CAduser, but someone who is managing a CAD project whereby we need to covert the files to Microstation. My AutoCAD person has limited experiece doing this so I thought I would turn to you for your expertise.
    I've read that you can convert AutoCAD files to .dxf and import into Microstation but will that keep the integrity of the file? As you guys probably know, you cannot covert directly from one to the other because fonts, line weights, etc. don't translate well.
    I was wondering if can get some advice as to how to do this and is the process easy or is it timeconsuming.
    Thank you all.
  2. #2
    Super Moderator rkmcswain's Avatar
    Computer Details
    rkmcswain's Computer Details
    Operating System:
    Windows 7 Pro x64
    Motherboard:
    Intel DZ77RE-75K
    CPU:
    i7-3770K 3.50GHz
    RAM:
    32GB
    Graphics:
    Nvidia Quadro 2000
    Primary Storage:
    125GB SSD
    Secondary Storage:
    500GB SATA
    Monitor:
    ASUS 27" / ASUS 24"
    Discipline
    Civil
    Using
    Civil 3D 2013
    Join Date
    Sep 2005
    Location
    Houston
    Posts
    3,633
    Default
    No matter how you slice it, there is no perfect conversion to/from DGN/DWG. DXF files have little bearing on the problem.
    Microstation can read/write .DWG files, -or- are you having to provide DGN to fulfill a contract? If the latter, you will probably find that it's better to do the work in the required file format up front than to try and convert later.
    There are batch converters out there (google it), or AutoCAD Map can directly export DGN files.
    Regardless of how it's done, expect problems.
  3. #3
    Luminous Being dbroada's Avatar
    Computer Details
    dbroada's Computer Details
    Operating System:
    XP Pro
    Computer:
    Dell
    CPU:
    Intel Xeon 2.13GHz
    RAM:
    2GB
    Graphics:
    NVIDA Quadro FX 580
    Monitor:
    DELL 23" & SAMSUNG 21"
    Discipline
    Electro/Mech
    dbroada's Discipline Details
    Occupation
    Design Engineer
    Discipline
    Electro/Mech
    Using
    Electrical 2013
    Join Date
    Nov 2005
    Location
    Sussex, UK
    Posts
    5,059
    Default
    have to agree there. We had a contract that required microstation files. As we only have AutoCAD that's what we did them in and used a batch converter. It got MOST of the way there. The one thing it couldn't handle was extended font sets. Not normally a problem but as the final text was in Portuguese (for Brazil) our client got upset that all the accents were being missed off. Despite insurances from the software supplier this was never resolved. The drawings have now either been finished in brazil or still contain spelling mistakes.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  4. #4
    Forum Newbie
    Using
    not specified
    Join Date
    Dec 2005
    Posts
    2
    Default Thank you
    I really appreciated the responses listed here. I had a feeling this was the case and I may actually go with a company in TX that does this type of conversion. We do need to covert to fulfill a contract and since we did not have anyone who was a microstation user, we used our CAD guys to do the project.
    Thanks again!
  5. #5
    Computer Details
    Operating System:
    Windows 7 Pro x64
    Motherboard:
    Intel DZ77RE-75K
    CPU:
    i7-3770K 3.50GHz
    RAM:
    32GB
    Graphics:
    Nvidia Quadro 2000
    Primary Storage:
    125GB SSD
    Secondary Storage:
    500GB SATA
    Monitor:
    ASUS 27" / ASUS 24"
    Discipline
    Civil
    Using
    Civil 3D 2013
    Join Date
    Sep 2005
    Location
    Houston
    Posts
    3,633
    Default Re: Thank you
    Quote Originally Posted by viennawriter
    Thanks again!
    Our company went down this road several years ago. First a small project where they thought about working in ACAD and convert to MS. Then for the next project, they thought about having ACAD users 'learn' MS. In the end the realization was to hire MS users who knew MS, and do it in MS in the first place.
  6. #6
    Full Member
    Using
    not specified
    Join Date
    Mar 2006
    Posts
    26
    Default
    I agree this is a bit tricky and the conversion may depend on what the client requires in Microstation.
    In my perticular case I used AutoCAD's DGNEXPORT command, but before using I had to do the following in the dwg file:
    1- Make sure there are no xrefs referenced. Block can be used. All entities have to be individual, and model space is used.
    2- For site plans, make sure "north is pointing upward and the plan is in UCS coordinates. This means if looking at the drawing normally and north was pointing say to the right, then site plan should be pointing up and everything else (text, notes, title block, etc) should be rotated to the right.
    3- If you list any entitly is should be either a block, indivudual line, or text ... again all in model space.
    4- After this the use the DGNEXPORT command.
    Hope this helps.
    Quote Originally Posted by viennawriter View Post
    Thanks again!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
