Results 1 to 4 of 4
    Senior Member Cat's Avatar
    Electrical 2008
    Jul 2010
    Georgia
    147
    Default Command Line Prompt For Add Attribute
    Does anyone know if there is a command line prompt for the Add Attribute function? I'm writing a script and haven't been able to find any reference to it in my reference material. Thanks
    Senior Member
    Mechanical 2008
    Feb 2006
    England (Leeds)
    287
    Type '-ATT' in the command prompt?
    Ste G
    Director
    UK-CAD Solutions Ltd.
    UKCADS@googlemail.com
    Electrical 2008
    Jul 2010
    Georgia
    147
    No, -ATT is the same as -ATTDEF which defines an attribute. The command I'm attempting to invoke actually adds an attribute to a predefined block, but thanks for trying.
    Electrical 2008
    Jul 2010
    Georgia
    147
    I've come to the conclusion that the task I was trying to accomplish can't be done with a script because the "utility" within the command "Add Attribute" is not currently supported. If the I/O modules had been assembled in a "block" format as opposed to "parametrically" built, it would have been as simple as updating the affected blocks and replacing them throughout the Project. It's a rare circumstance that you would ever have to do that at the end of a job, but on the rare occasion that you might, it sure is less expensive to be able to, as opposed to manually manipulating each I/O module.
  1. How to overwrite last line in command prompt?
    By M76 in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Jun 2010, 09:37 am
  2. Change Block Attribute: Tag/Prompt/Value
    By AQucsaiJr in forum AutoCAD General
    Last Post: 23rd Oct 2009, 10:09 am
  3. where is command prompt?
    By Kari in forum Revit General
    Last Post: 27th Feb 2008, 11:54 pm
  4. command line prompt
    By paul lbd in forum AutoCAD Beginners' Area
    Last Post: 1st May 2007, 12:30 pm
  5. Attribute prompt order ?
    By marcus in forum AutoCAD Drawing Management & Output
    Last Post: 16th Feb 2005, 08:56 pm
