OLD SCHOOL Posted July 22, 2010 Share Posted July 22, 2010 Sometimes when hatching with concrete pattern, the small triagular shapes come out as lines. If you alter the ucs angle and re-hatch it works fine - not sure why. Any Ideas?? Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 22, 2010 Share Posted July 22, 2010 When the plane that is hatched is rotated in 3d, the triangles are foreshortened. Quote Link to comment Share on other sites More sharing options...
Glen1980 Posted February 25, 2011 Share Posted February 25, 2011 I get this problem in LT as well. Could it be because I can't pick the z axis when I set new UCS's? Quote Link to comment Share on other sites More sharing options...
eldon Posted February 25, 2011 Share Posted February 25, 2011 This a known feature of the concrete hatching, when you are a long way from the 0,0 coordinate. Making a UCS moves the origin closer to the hatch for the older versions of AutoCAD, but there should now be an option for doing this in the Hatching dialogue box. Quote Link to comment Share on other sites More sharing options...
Glen1980 Posted February 25, 2011 Share Posted February 25, 2011 Funnily enough I had mine about 10m from the named UCS but 500KM from the world and the hatch worked when I had the UCS set to world! Quote Link to comment Share on other sites More sharing options...
Organic Posted February 25, 2011 Share Posted February 25, 2011 I too have this problem quite often and change 'Specified Origin' -> 'Default to boundary extents' in the Hatch properties to get it to display correctly. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 1, 2011 Share Posted March 1, 2011 Gravel will do the same as well go silly when viewed we just re set the origin point in the hatch properties to be a corner of the object being hatched. Quote Link to comment Share on other sites More sharing options...
Jack_O'neill Posted March 1, 2011 Share Posted March 1, 2011 Does changing the scale of the hatch have anything to do with it? I never get all that far out I guess, have never seen it do that. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 1, 2011 Share Posted March 1, 2011 I too have this problem quite often and change 'Specified Origin' -> 'Default to boundary extents' in the Hatch properties to get it to display correctly. Same here. Fixes the problem every time. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 2, 2011 Share Posted March 2, 2011 If your doing civil drawings and using real world co-ordinates as an example 285588.123,5763207.123 then the problem creeps in pretty quick we just all know about it. Quote Link to comment Share on other sites More sharing options...
petesperry Posted March 2, 2011 Share Posted March 2, 2011 Awesome, thanks guys, i have been having this problem for ages, but could never find the right description to bring up these posts!! I knew someone out there would have had the same problem and then the answer too!! WOo hoo, thanks! 1 happy technician, sad really, this really has brightened up my day! Pete Quote Link to comment Share on other sites More sharing options...
