How to pick a variable number or points
Alhazred
In my routine I have to ask the user to pick some points, all the points he wants.
To do that I've done like this and it works
(setq points nil)
(setq pt (getpoint "\nSelect a point:"))
(while (/= pt nil)
 (setq points (cons pt points))
In this way, the user, to stop the selection has to right click.
Is there a better way to do the same?
This is the solution used by AutoCAD also to end a selection cycle. You may add the selection to WHILE test to avoid calling it twice:
(while (/= (setq pt (getpoint "\nSelect a point <ENTER to exit>:")) nil)
Regards,
Here's mine...
(defun AT:GetPoints (/ lst pt)
 ;; Return list of picked points
 ;; Alan J. Thompson, 06.18.10
 (if (car (setq lst (list (getpoint "\nSpecify first point: "))))
     (while (and (if (> (length lst) 2)
                   (setq pt (initget 0 "Close")
                         pt (getpoint (car lst) "\nSpecify next point [Close]: ")
                   (setq pt (getpoint (car lst) "\nSpecify next point: "))
                 (/= pt "Close")
       (mapcar (function (lambda (a b) (and a b (grdraw a b 1 1))))
               (setq lst (cons pt lst))
               (cdr lst)
     (redraw)
     (reverse (cond ((= pt "Close") (cons (last lst) lst))
                    (lst)
Edited by alanjt
A few from my library, some more useful than others
;;---------------------=={ Get Points }==---------------------;;
;;  Returns a list of selected points.                        ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
;;  Arguments: - None -                                       ;;
;;  Returns:  List of 3D Points                               ;;
(defun LM:GetPoints ( / lst pt )
 ;; Lee Mac  ~  05.03.10
 ;; Returns a list of selected Points
 (if (car (setq lst (list (getpoint "\nPick First Point: "))))
   (while (setq pt (getpoint "\nPick Next Point: " (car lst)))
     (mapcar
       (function
         (lambda ( from to ) (grdraw from to 3 1))
       (cdr (reverse (setq lst (cons pt lst))))
       (reverse (cdr lst))
 (redraw) (reverse lst)
(defun LM:GetWindow ( / lst pt )
 ;; Returns a list of Points defining the window.
   (while (setq pt (getpoint "\nPick Next Point: " (car lst))) (redraw)
     (mapcar
       (function
       (append lst (list pt)) (setq lst (cons pt lst))
(defun LM:GetDynWindow ( / lst pt gr )
 ;; Lee Mac  ~  31.01.10
 (if (and (car (setq lst (list (getpoint "\nPick First Point: "))))
          (princ "\nPick Next Point: "))
   (while
     (setq pt
         (while (and (= 5 (car (setq gr (grread 't 5 0)))) (listp (cadr gr))) (redraw)
           (mapcar
             (function
             (cons (cadr gr) lst) (append lst (cdr gr))
         (cond ( (listp (cadr gr)) (cadr gr) ))
     (cond ( pt (setq lst (cons pt lst))))
