fjaniswilshire-homes Posted July 26, 2010 Share Posted July 26, 2010 I have drawing that are labeling the lines at feet. It takes the nearest inches and rounds it off to the even number that is next. Example 10'-9" equals 12'. I want to learn how to take those amounts and put them in a table that will have the quantity also. I have tried "eattext" to count the blocks but I need to count the line and how many there are. Puttting them into blocks will be more steps and that's what I am trying to avoid. Example 2x12 at 16' - 45 of them counted so there are 45 2x12's at 16'. Any ideals? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 27, 2010 Share Posted July 27, 2010 I would try to use a block as a label rather than a dimension then you could display 10' 9" but have a hidden attribute 12' then your eattext could sort on the block attributes the 12' possibly also a field so change line length and attribute updates. You need a lisp etc draw line then place block and label. probably two routines 1 for exsiting and 2nd that does both. Quote Link to comment Share on other sites More sharing options...
