Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2007
    Jul 2010
    2
    Unhappy Flattening 3D Roof
    I'm having the hardest time trying to figure this roof out. What I'm trying to do is take the roof and convert it from its 3D combined state to it's individual planar elements (flat and parallel to the screen).
    I don't mean:
    • go into paper space once they have been pulled apart,
    or
    • a different viewpoint after they have been separated.
    This is completely driving me insane. I can visually see myself grabbing the planes and putting them flat on a piece of paper but why is it so damn hard on ACad'07!?
    Hope I'm making myself clear. Thanks in advance.
    Don't let the names confuse you they are in no way Axonometric. (Roof Axon Comb. is the combined version.)
    Roof Axon Combined.dwg
    Roof Axon.dwg
    Senior Member viviancarvalho's Avatar
    HVAC
    viviancarvalho's Discipline Details
    Draughtsman HVAC
    HVAC
    AutoCAD 2010
    Oct 2009
    Bahrain
    152
    Welcome to the Cadtutor forum.
    Your problem can be easily solved by
    the use of a command "flatten".
    check out the attachment.
    Regards
    Vivian
    Forum Newbie
    AutoCAD 2007
    Jul 2010
    2
    Default Thanks!
    Thanks for welcoming me and thank you for your immaculate response. This should have been the first place I went but I'm still new to most of ACad's commands. Thank you so much!
    HVAC
    Draughtsman HVAC
    HVAC
    AutoCAD 2010
    Oct 2009
    Bahrain
    152
    You are always welcome
  1. how to draw a skillion roof + roof question
    By Richo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Jul 2010, 04:57 pm
  2. making a half octogon roof roof
    By chelsea1307 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Aug 2009, 09:58 pm
  3. project spanish roof hatch pattern over a conical roof in 2D
    By erona in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jan 2007, 01:40 pm
  4. flattening 3d to 2d
    By cadsultant in forum AutoCAD Drawing Management & Output
    Last Post: 1st Mar 2005, 08:18 pm
  5. Flattening a 3d model
    By Cyclopean in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Mar 2003, 02:57 pm
