Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
    Full Member
    AutoCAD LT 2010
    May 2010
    39
    Default Hardware Acceleration for 2011 AutoCAD LT; Laggy mouse
    I upgraded from 2010 LT to 2011 LT. However the newer software on a MUCH faster computer is un-usable if dynamic imput is enabled. however the older software and computer run this fine. How can I fix this?
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,479
    A "laggy" mouse may be due to nothing more than an outdated driver. When you purchased this much faster computer did you retain your old mouse and keyboard?
    Full Member
    AutoCAD LT 2010
    May 2010
    39
    Completely new mouse and keyboard. This same laggy mouse issue also happens on other computers with AutoCAD 2011. It somewhat improves when you turn off dynamic input.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,479
    I just loaded 2011 yesterday and have had no mouse related issues. I have not tested it with Dynamic Input enabled. I will do so momentarily and let you know the results. I'll be back.
    An update.
    I enabled Dynamic Input and have experienced no lag what-so-ever. I'm using my original (older) MS wheel mouse and a four year old Logitech keyboard.
    I have the company-wide TrendMicro antivirus program running, MS Outlook, Windows Explorer and my Internet connection running in the background.
    My OS is WinXP S.P. 3 (32-bit) running the 32-bit version of ACAD 2011. There is 4GB of RAM installed on this (work) system and I have enabled the 3GB switch in my boot.ini file.
    What are the specs on your computers?
    By the way, mine is a standalone system as far as AutoCAD goes. You're networked?
  5. #5
    Full Member
    AutoCAD LT 2010
    May 2010
    39
    great. thanks. it sucks that dynamic input works fine with 2010 and not with 2011. ALSO ITS LT not regular.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,479
    I am fully aware that you are running LT while I am running the full blown package. So, that makes me wonder why our experiences aren't reversed. With more "overhead" I should be having problems while you sail right along.
    What are your system specs?
    Has this been a problem right from the start?
    Do mouse-related problems appear when using other programs (ex. - MS Word or Excel)?
    What model mouse is being used?
    Have you checked your mouse properties?
  7. #7
    Full Member
    AutoCAD LT 2010
    May 2010
    39
    problem happens on over 3 computers. all different equipment. occurs starting right after install within autocad. Everything else works great. Computers run windows 7 but also happens in vista. not sure on xp.
    Laptop: 2 ghz core 2 duo, 2 gb ram, 64bit, microsoft air mouse / pad
    Desktop 2.4 ghz core 2 quad, 4 gb ram, 64 bit, microsoft mosue (model ???)
  8. #8
    Super Member Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Independent Architectural Draftsman
    Construction
    Residential Homes, Construction and Renovation
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,777
    Here's that "Did you check the gas guage." question.
    You're not running a MS roller ball type mouse are you?
    The only problems I ever experienced with ACAD LT was with one of those museum pieces. The thing was totally unusable and worse with Dyn Input and Tool Tips on. I couldn't even get the crosshairs to center on a grip. it jiggled all over the place. It was not that long ago, at a work place with a tight boss. Took me two weeks to convince him to let me even buy my own optical mouse and install it.
    Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
  9. #9
    Full Member
    AutoCAD LT 2010
    May 2010
    39
    nope a normal wireless mouse.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,777
    Of course you have optical mouses (Mices?) other than the touchpad.
    Don't use pointer acceleration.
    Don't use smart pointer.
    Don't use mouse trails.
    Set all scroll increments to 1 line.
  1. AutoCAD 2011 and many other Autodesk 2011 Products Released.
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 25th Mar 2010, 02:46 pm
  2. Hardware Acceleration Problem
    By ARYT in forum SolidWorks
    Last Post: 11th Sep 2009, 02:05 pm
  3. Hardware acceleration drop-down menu is blank
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 5th Sep 2006, 12:18 pm
  4. Hardware Acceleration options unavailable
  5. AUTOCAD and Hardware
    By xauthenticx in forum AutoCAD Drawing Management & Output
    Last Post: 27th Aug 2006, 04:40 pm
