Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Default Is there a command to unblock a blocked object?
    I want to modify a blocked object, change the length of a line in a block and I can't do it.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Not sure what you mean by blocked objects? It is about a block not allowed for explosion? Or is just about entities contained in a block definition?
    Anyway, to edit items contained in a block, please use the BEDIT command.
    Regards,
    Forum Newbie DBcadmanager's Avatar
    Civil
    DBcadmanager's Discipline Details
    Senior Designer
    Civil
    Civil 3D 2012
    Jul 2010
    3
    what version of autocad are you using?
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    I am using AutoCad 2007.
    As for msasu reply, by blocked objects I mean entities contained in a block definition. I will try bedit command.
  5. #5
    Civil
    Senior Designer
    Civil
    Civil 3D 2012
    Jul 2010
    3
    you can also click on the block ones and right click and chose block editor..in that window you can make your necessary changes. and then when you are done click on close block editor and make sure you save it...
  6. #6
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    REFEDIT command may also do the same work, if BEDIT isn't available in AutoCAD 2007.
    Regards,
  7. #7
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Bedit works in AC2007 and it brings up "Block Authoring Palettes" with three tabs which is totally odd for me.
    I think first I have to read its help menue in AC2007 or if you any suggestion for a better place to learn more on bedit.
  8. #8
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    For the moment may simply ignore those pallets, are for dynamical blocks. Simply do the required changes and press <Close Block Editor> button to end editing – will be asked chouse to save or discard changes.
    Regards,
  9. #9
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Yes it works. Thanks.
  10. #10
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    You're welcome!
    Regards,
  1. Hidden/blocked wipeouts
    By BuntyBunty in forum AutoCAD General
    Last Post: 23rd Nov 2009, 10:20 am
  2. Explode command blocked using Autocad LISP, how to solve it?
    By RevolverSly in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Sep 2009, 06:17 pm
  3. PAN blocked
    By dusko in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2008, 02:16 pm
  4. problem with blocked dwg files
    By vip3r54 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2008, 01:58 pm
  5. help! everythings blocked/xref-ed?
    By nwsurfer07 in forum AutoCAD General
    Last Post: 4th Oct 2007, 04:55 am
Tags for this Thread
