Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 7 x64
    Dell Precision T7610
    Intel Xeon E5-2630 v2 (six core)
    32 Gb
    3 Gb Nvidia Quadro K4000
    1 TB
    2x 1920x1080 Dell Ultrasharp U2312HM
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD 2015
    May 2008
    Rockford, Illinois
    763
    Wow, I must be really behind the times and out of the loop. I don't see a single response to explode the block (or to be more precise the block reference, otherwise known as an insert object)
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
  2. #12
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,781
    Quote Originally Posted by khoshravan View Post
    Yes it works. Thanks.
    If you have more than one occurance of this block in the drawing, all of them will change upon saving the edited block.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  3. #13
    Senior Member cadvision's Avatar
    cadvision's Computer Details
    Windows 10
    DELL inspiron
    i7-3632QM CPU @2.2GHz
    8GB
    1TB
    aoc 24"
    Multi-disciplinary
    cadvision's Discipline Details
    Software distributor, contract drafting/scanning
    Multi-disciplinary
    Electro/Mechanical Drafty since Drawing Board. Mainly work in Petrochemical and Dairy Industries. Specialise in Maintenace, Process and I&E Drafting since 1980.
    AutoCAD 2016
    Sep 2008
    New Zealand
    202
    explode
    it converts blocks back to base elements. If there are attributes you loose the text.
    burst
    explodes but if there are attributes that have been filled in, these are converted to text
  4. #14
    Senior Member khoshravan's Avatar
    khoshravan's Computer Details
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Quote Originally Posted by Dana W View Post
    Which method are you talking about? bedit?
    Good point. I didn't know that.
  5. #15
    Windows 7
    Sony Vaio
    AutoCAD 2010
    Feb 2009
    Tabriz
    482
    Quote Originally Posted by cadvision View Post
    explode
    burst
    As Patrick mentioned earlier, there was no reply on explode or burst till his post.
    Thanks for your input. By unblocking I meant editing it and saving again. For this reason I like the bedit command. But also I learned what is explode and burst as well. Thanks
  6. #16
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    The idea is that for a block you have his definition (which isn’t visible in drawing) and (but not necessary) a number of copies of that definition (block instances). When you modify one of those copy, you affect in fact the block definition, so all instances will be modified. Will see the same effect if you create a new block with the same name of an exiting one.
    Regards,
  7. #17
    Forum Newbie
    AutoCAD 2013
    Nov 2014
    1
    explode command may also work
  1. Hidden/blocked wipeouts
    By BuntyBunty in forum AutoCAD General
    Last Post: 23rd Nov 2009, 10:20 am
  2. Explode command blocked using Autocad LISP, how to solve it?
    By RevolverSly in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Sep 2009, 06:17 pm
  3. PAN blocked
    By dusko in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2008, 02:16 pm
  4. problem with blocked dwg files
    By vip3r54 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2008, 01:58 pm
  5. help! everythings blocked/xref-ed?
    By nwsurfer07 in forum AutoCAD General
    Last Post: 4th Oct 2007, 04:55 am
Tags for this Thread
