hughesey Posted July 29, 2010 Share Posted July 29, 2010 Hi guys, i'm really new to this, been trying to find examples for a couple of days now on how to edit a load of drawings in a folder and up-rev them all & then simply save them. To up-rev them all there's a block that needs altering, and I need to select a couple of pieces of text to erase or rename. Thats all, the tag in the block will always be the same. Can someone point me in the right direction, or provide a few examples I can use.... I've done about 1200 drawings so far manually, and there's more than twice as much of that left to do. I've been trying to write lisp things out, but they're no good, I can get it to erase the things and thats it. Kind of lost now how to do anything else....... Quote Link to comment Share on other sites More sharing options...
dbroada Posted July 29, 2010 Share Posted July 29, 2010 if its a script you want (I like scripts but not everybody here does) start with pen and paper and write down excacly what you type (or if you use buttons, what gets echoed to the F2 screen). That is the command sequence you need in your script. What modifications are you doing to the block? This may need lisp rather than script. Quote Link to comment Share on other sites More sharing options...
