Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD 2008
    Apr 2009
    44
    Smile Xref not showing in print preview
    Greetings,
    I am drawing up an electrical and lighting schematic using an xreffed GA plan. However in the print preview the xreffed plan is not showing up at all, also the title block is not showing up and that is merely lines in paperspace. The xref is not on a layer that is frozen or locked or set not to print.
    Can anybody help?
    Many thanks
    BB.
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,667
    Open the Layer Manager and check if it on the default layer ... if not ..check if the NEW VP FREEZE for the
    Layer which the Xref drawing laying on.
    Or re-attach the Xref drawing once again.
    Hope this would get it worked.
    Senior Member
    AutoCAD 2011
    Jul 2009
    London, UK
    139
    Send us the drawing if your still having problems.
    Full Member
    AutoCAD 2008
    Apr 2009
    44
    Hi, the drawing is not on the default/defoints layer and the New VP Freeze command is not on for the layer that the xref has been placed on. I have opened and reattached again but still nothaving any luck.
    Any other suggestions? I have to get these out for client approval today.
    BB.
  5. #5
    Full Member
    AutoCAD 2008
    Apr 2009
    44
    Here's a thing, I just unloaded the xref and did a print preview and everything was showing except for the xref ofcourse. But when I turn the xref back on and do a print preview, nothing is showing.
  6. #6
    Senior Member
    AutoCAD 2011
    Jul 2009
    London, UK
    139
    Draw order? Put the xref behind the objectS?
  7. #7
    Full Member
    AutoCAD 2008
    Apr 2009
    44
    Nope. This has not made any change.
  8. #8
    Senior Member
    AutoCAD 2011
    Jul 2009
    London, UK
    139
    Are there wipeouts on the drawing which are hiding things? Wipeouts can be a pain
    Type "TFRAMES" that will turn the frames on. then have a look around for wipeouts (Or doe a QSELECT see if wipeouts are there)
  9. #9
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,667
    detach and attach it once again.
  10. #10
    Full Member
    AutoCAD 2008
    Apr 2009
    44
    Hmm still no change unfortunately....
  1. XREF not showing up in print preview
    By rusty in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jan 2013, 11:59 pm
  2. plot preview showing and printing in color HELP!!!
    By dboy413 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2008, 10:44 pm
  3. Print Preview and Print does not equal Drawing
    By reggy in forum AutoCAD General
    Last Post: 19th Aug 2008, 03:53 am
  4. Plotstamp in Print Preview
    By Shep in forum AutoCAD Drawing Management & Output
    Last Post: 18th Apr 2005, 10:12 pm
  5. print preview xref
    By kiedron d in forum AutoCAD Beginners' Area
    Last Post: 9th Dec 2004, 03:10 pm
