I have a C# application that calls a LISP program to insert blocks into a drawing. When I run this LISP program from the C# interface it renders all existing blocks with the same name as: ** Undefined block #2129780480
The process is:
1. I use the INSERT command from the command line to place a block called REVISION in the drawing.
2. I then run the C# application which calls the LISP program that inserts the same block (REVISION).
3. The block reference inserted from the command line becomes undefined.
The code I use to call the LISP program is:
//Get a reference to the active document
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
//Convert the document to an Interop version
AcadDocument curAcadDoc = (AcadDocument)doc.AcadDocument;
//Send the Visual LISP Load Command to the editor
curAcadDoc.SendCommand("(vl-load-com) "/*space after closing paren!!!*/);
//Which size Titleblock is being used (D or F)
if (TitleBlockSize.Equals("D"))
//D Size Standard Width Device List
if (this.radioButton1.Checked)
//Set up the full path to the LISP program
string lispPath = "Z:/NPID16/HCAD/DLIST20";
//Format the string to load the specified LISP program
string loadStr = String.Format("(vl-load-all \"{0}\") "/*space after closing paren!!!*/, lispPath);
//Send the formatted command to the editor
curAcadDoc.SendCommand(loadStr);
//Now call the LISP program
curAcadDoc.SendCommand("_DLIST20 ");
If I load and run the LISP program outside the C# application there are no problems.
