Results 1 to 2 of 2
    Forum Newbie
    AutoCAD LT 2010
    May 2010
    5
    Default leaders/multileaders obscured when hidden lines enabled
    Hello,
    I am trying to figure out how to stop AutoCAD LT 2010 from hiding my leaders and multileaders behind elevated solid objects, when using the hide command (or plotting with hidden lines enabled). I can find no way to elevate those items, nor any command to set a general override (like the HIDETEXT setting). Leader has a vertex Z property. but when I set it the darn thing always resets to 0 immediately. Neither leader nor multileader have an elevation property.
    I see two workarounds:
    a) place the annotations down in paperspace
    b) move all solid objects below the base plane
    advice?
    Senior Member
    AutoCAD 2010
    Aug 2009
    Baltimore, MD
    111
    Would the TEXTTOFRONT command help? It works for dimensions also.
  1. Lines and leaders random snapping!
    By james hogan in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2010, 04:20 pm
  2. Showing dashed lines for obscured edges
    By franky in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Mar 2010, 12:40 pm
  3. Blocks and Leaders/Multileaders
    By ibnut in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2009, 10:05 pm
  4. Constructing Hidden Lines and Construction Lines
    By Colgrave in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2009, 04:01 pm
  5. Hidden lines, not being hidden in 3D view
    By deadseasquirrels in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Sep 2003, 11:08 am
Tags for this Thread
