Results 1 to 7 of 7
Thread: Create spline
    Full Member
    AutoCAD 2006
    Jul 2010
    43
    Default Create spline
    Hi all!
    How can I create a spline from n points?
    (command "spline" point1 point2 pointi ... pointn) works, but I have to specify the start and end tangent. I want to do it automaticly i.e. 0, 0.
    How can I do that?
    That'd be better if I could make it with the entmake command!
    Thanks any help!
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    I have moved your question to its own thread, please start a new thread for each new question.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    To get default tangents just use "" (equivalent to <ENTER>) – a series of 3 "" at the end of the function call will do the job (one to end points input and the folowing two to accept default tangents:
    Code:
    (command "_spline" point1 point2 pointi ... pointn "" "" "")
    Regards,
    PS. Maybe the best location for this thread is under AutoLISP, Visual LISP & DCL sub-forum.
    Full Member
    AutoCAD 2006
    Jul 2010
    43
    Thanks a lot!
    And I modify my problem: I have a list that contains n points, and I want to make spline!
  5. #5
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    For this case can use the below approach:
    Code:
    (command "_SPLINE")   ;start command function
    (foreach thePoint MyPointsList
     (command thePoint)   ;parse points list and feed the SPLINE command
    (command "" "" "")    ;close points input and accept default tangents
    Regards,
  6. #6
    Full Member
    AutoCAD 2006
    Jul 2010
    43
    Thanks a lot!
    You are great!
  7. #7
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    You're welcome! Glad to help you.
    Regards,
  1. To create or not to create threads
    By Polanka in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Nov 2009, 10:18 pm
  2. spline to arc
    By todorb2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Sep 2008, 09:38 pm
  3. Spline to Arc
    By todorb2000 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Sep 2008, 02:14 pm
  4. Spline
    By yeva in forum AutoCAD Beginners' Area
    Last Post: 15th Mar 2007, 06:34 pm
  5. spline
    By Mike Ravenwolf in forum AutoCAD General
    Last Post: 6th Dec 2005, 04:01 pm
