bucks87 Posted August 3, 2010 Share Posted August 3, 2010 Hi all, I have got as far as understanding the difference between CTB and STB plot styles, and have identified I require STB, as I want to apply plot styles to individual layers as opposed to certain colours. I have converted my drawing from CTB to STB and have set up an STB plot style to acheive what I would like. However I am unable to apply the styles held within this STB to individual layers in the layers property manager. In the plot style coloumn they are slightly greyed out, upon clicking on a layer a 'Select Plot Style' box appears which lists the "normal", "style 1" & "style 2" that I have created. However upon choosing a different style and hitting ok it doesnt apply my selection. Any ideas why anyone? I am reasonably confident my STB file is setup correctly, as it is possible to apply the styles to objects using the object properties box, and for these to then be printed correctly to the style assigned. PS - I am using AutoCAD LT 2010 Quote Link to comment Share on other sites More sharing options...
PaulS00 Posted May 25, 2012 Share Posted May 25, 2012 Bump for same question Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 26, 2012 Share Posted May 26, 2012 Have you tried opening a default AutoCAD STB Template to see if that works first to narrow down the possible problem? Quote Link to comment Share on other sites More sharing options...
