+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,144
    Default
    The purpose of creating a Restore Point is specific to the Registry no matter what drive the program is installed on. Not too many users know how to do a separate back up of the Registry so I'll give you points for that.
    Well I do hope your system continues to function without any further problems. Thanks for sharing the info with us.
  2. #12
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Aug 2010
    Location
    Perth, Western Australia
    Posts
    4
    Default
    I've tried all the above but it still doesn't work for Autocad 2011. I've even checked the Registry Uninstall setting.
    When I try to reinstall is says that Autocad 2011 English is already installed.
    If I change the language to French it will let me install. Pity I don't speak french.
    There has to be an entry there somewhere.
  3. #13
    Full Member dtaylor's Avatar
    Computer Details
    dtaylor's Computer Details
    Operating System:
    Windows 7 64 bit
    Using
    AutoCAD 2012
    Join Date
    Jun 2010
    Location
    Maine, USA
    Posts
    73
    Default
    Give a program called Revo Uninstaller a try. There's a free version that normally does a good job at removing all traces of a program off your computer.
  4. #14
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Aug 2010
    Location
    Posts
    4
    Default
    Using Revo Uninstaller made no difference.
  5. #15
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,144
    Default
    What version of Windows are you running?
  6. #16
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Aug 2010
    Location
    Posts
    4
    Default
    Running Windows XP
  7. #17
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,144
    Default
    XP huh? Don't see why it wouldn't work. You might try the old standby Regclean from those fine folks at Microsoft. Create a Restore Point beforehand. Note too that Regclean creates a backup of your Registry that you can reload if you don't like the results it gives you.
  8. #18
    Forum Newbie
    Using
    Civil 3D 2012
    Join Date
    Aug 2011
    Posts
    1
    Default
    Quote Originally Posted by paul1966 View Post
    MSICUU2.exe is correct, i made a typo. i found the program here-
    http://majorgeeks.com/Windows_Instal...ity_d4459.html
    Just wanted to thank you Paul... Your old thread and that utility worked for Win 7 64bit 2011 Install issue...
    Problem started with 2011 install and another survey software on top of that... some arx files and some other bad errors and botched uninstall left it saying Autocad 2011 was still installed...
    Ran ccleaner to clean up the registry as well as 2011 removal vbs scripts and nothing worked... all sorts of things were left in the registry saying that 2011 was still present but it wasn't... and most definitely not in the Uninstall Programs List...
    Installed MSI Cleanup Utility - and it was in the list both 2011 and the language pack...
    Removed both via the tool - Rebooted and the new install went perfectly...
    Again... a year later and that advice was perfect.
  9. #19
    Forum Newbie
    Computer Details
    Knightrazer's Computer Details
    Operating System:
    Windows 7 Ultimate
    Motherboard:
    Asus M2N68-AM+
    CPU:
    AMD Athlon 7750 Dual Core
    RAM:
    2GB
    Graphics:
    MSI Nvidia n9400GT
    Primary Storage:
    250GB
    Monitor:
    LG 21" LCD
    Using
    AutoCAD 2011
    Join Date
    Jan 2012
    Location
    Kerala, India
    Posts
    1
    Default Thanks Paul
    Your Solution msicuu2 worked perfectly... Thanks a lot
  10. #20
    Forum Newbie
    Using
    Revit Architecture 2011
    Join Date
    Feb 2012
    Posts
    1
    Default New Resolution
    I was having this same problem with Revit 2011 (X64 on Win 7). I thought that program might do the trick, but it didn't. Thankfully, this one did for me - http://support.microsoft.com/mats/Pr..._and_Uninstall
    Hope this helps someone else, too.
Similar Threads
  1. Ensuring a clean uninstall of AutoCAD
    By ReMark in forum Useful Links
    Last Post: 28th Jun 2010, 11:30 am
  2. AutoCAD 2011 and many other Autodesk 2011 Products Released.
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 25th Mar 2010, 02:46 pm
  3. autocad 2009 won't uninstall
    By spursnutter in forum AutoCAD General
    Last Post: 4th Sep 2009, 04:58 pm
  4. Uninstall then reinstall AutoCAD LT 2008
    By uddfl in forum Software & Licensing
    Last Post: 27th Jun 2009, 06:25 pm
  5. unable to uninstall Autocad 2004
    By blkpagoda in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2006, 11:47 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
