Something like this seems more intuitive to me:
Code:
(defun c:MakeField ( / *error* object convlst property units prec pref suff zval conv doc spc e p unit )
(vl-load-com)
;; © Lee Mac 2010
;; Adjustments ;;
(setq object "HATCH" ;; Object Type (cannot be nil)
property "Area" ;; Field Property (must belong to object, else field = #### )
units 2 ;; Units (integer: 1-6 or nil)
prec 3 ;; Precision (integer: 0-8 or nil)
pref nil ;; Prefix (string or nil)
suff nil ;; Suffix (string or nil)
conv nil ;; Conversion Factor (real or nil)
zval nil ;; Hide Z-Vale (t or nil)
(setq convLst '(("m²" . 1) ("ha" . 0.0001) ("km²" . 0.000001)))
(defun *error* ( msg )
(princ (strcat "\n** Error: " msg " **")))
(LM:ActiveSpace 'doc 'spc)
(initget "0 1 2")
(setq prec
(atoi
(cond
(getkword "\nSpecify Precision [0/1/2] <0> : ")
( "0" )
(initget (LM:lst->str (mapcar 'car convLst) " "))
(setq unit
(assoc
(cond
(getkword
(strcat "\nSpecify Unit ["
(LM:lst->str (mapcar 'car convLst) "/") "] <" (caar convLst) "> : "
( (caar convLst) )
convLst
(setq suff (car unit) conv (cdr unit))
(while
(and
(setq e
(LM:SelectifFoo
(lambda ( x )
(eq object (cdr (assoc 0 (entget x))))
(strcat "\nSelect " object ": ")
(setq p (getpoint "\nPick Point for Field: "))
(LM:AddMText_MC spc p
(strcat "%<\\AcObjProp Object(%<\\_ObjId "
(LM:GetObjectID doc (vlax-ename->vla-object e)) ">%)." property
(if (apply 'or (list units prec conv pref suff))
(strcat " \\f \""
(if units (strcat "%lu" (itoa units)) "")
(if zval "%pt3" "")
(if prec (strcat "%pr" (itoa prec )) "")
(if (or pref suff) (strcat "%ps[" (cond ( pref ) ( "" )) "," (cond ( suff ) ( "" )) "]") "")
(if conv (strcat "%ct8[" (rtos conv) "]") "")
(defun LM:AddMText_MC ( space pt str / obj )
;; © Lee Mac 2010
(if
(not
(vl-catch-all-error-p
(setq obj
(vl-catch-all-apply (function vla-AddMText)
(list space (vlax-3D-point pt) 0. str)
(vla-put-AttachmentPoint obj acAttachmentPointMiddleCenter)
(vla-put-InsertionPoint obj (vlax-3D-point pt))
(defun LM:GetObjectID ( doc obj )
;; © Lee Mac 2010
(if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE")))
(vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
(itoa (vla-get-Objectid obj))
;;--------------------=={ ActiveSpace }==---------------------;;
;; Retrieves pointers to the Active Document and Space ;;
;; Author: Lee McDonnell, 2010 ;;
;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;;
;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;;
;; Arguments: ;;
;; *doc - quoted symbol other than *doc ;;
;; *spc - quoted symbol other than *spc ;;
(defun LM:ActiveSpace ( *doc *spc )
;; © Lee Mac 2010
(set *spc
(if
(or
(eq AcModelSpace
(vla-get-ActiveSpace
(set *doc
(vla-get-ActiveDocument
(vlax-get-acad-object)
(eq :vlax-true (vla-get-MSpace (eval *doc)))
(vla-get-ModelSpace (eval *doc))
(vla-get-PaperSpace (eval *doc))
;;-------------------=={ Select if Foo }==--------------------;;
;; Continuous selection prompts until the predicate function ;;
;; foo is validated ;;
;; Arguments: ;;
;; foo - predicate function taking ename argument ;;
;; str - prompt string ;;
;; Returns: selected entity ename if successful, else nil ;;
(defun LM:SelectifFoo ( foo str / e )
;; © Lee Mac 2010
(while
(setq e (car (entsel str)))
(cond
(eq 'ENAME (type e))
(if (not (foo e)) (princ "\n** Invalid Object Selected **"))
e
;;-------------------=={ List to String }==-------------------;;
;; Constructs a string from a list of strings separating ;;
;; each element by a specified delimiter ;;
;; Arguments: ;;
;; lst - a list of strings to process ;;
;; del - delimiter by which to separate each list element ;;
;; Returns: String containing each string in the list ;;
(defun LM:lst->str ( lst del )
;; © Lee Mac 2010
(if (cdr lst)
(strcat (car lst) del (LM:lst->str (cdr lst) del))
(car lst)
