Results 1 to 6 of 6
    Forum Newbie
    not specified
    Dec 2005
    4
    Default exporting / importing layers
    I have a set of drawings(electricity, pipe...etc) in different files and needed to be put onto a single plane to compare and check the location
    of the components.
    what is the best way to move these layers and replace them onto another file??
    Thanks a lot for help~~
    Forum Newbie
    not specified
    Dec 2005
    4
    I m using AutoCAD 2004
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    for just checking I use XREF. Either start with your base draing or a blank drawing and XREF in all the other drawings. Everything should then line up and you can UNLOAD/RELOAD each XREF to see how it matches.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
    Forum Newbie
    not specified
    Dec 2005
    4
    thanks for ur quick reply Dave, what I m using is the "INSERT" command. "XREF" does show a lot more informations. THX for ur suggestion~~
  5. #5
    Senior Member
    not specified
    Oct 2005
    UK
    156
    Use the Design Center (hold the Ctrl button and press 2). This will allow you to drag and drop layers from one drawing to another.
    Aled Taylor
    (File size is someone else's problem)
  6. #6
    Forum Newbie
    not specified
    Dec 2005
    4
    Thanks for all ur kind help~~
