Results 1 to 4 of 4
Thread: screw?
    Forum Newbie
    not specified
    Dec 2005
    Norfolk
    5
    Default screw?
    how do i draw a wood /self tapping screw in 3d with autocad 2004?
    i've tried a combination of extruding triangles around a helix but can't quite get it to look right (or convincing)
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Extruding a triangle along a helix you will get it twisted. Unfortunately you have no control over this twist so I would recommend you an other approach. Draw tree helixes representing the top and the bottoms of a thread (passing trough the corners of the triangle). Now create two surfaces between the larger helix and the two inner ones.
    Post here if you need more details.
    See HERE something similar
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Forum Newbie
    not specified
    Dec 2005
    Norfolk
    5
    many thanks for that.
    experimenting now...
    Forum Newbie
    AutoCAD 2007
    Jan 2007
    2
    i found a .3ds file but i have no idea how to import it, i'm not quite understanding how you link the small and large helix together if i was to make a screw myself in autocad2007... help ?
