Results 1 to 5 of 5
    Junior Member
    Architecture 2009
    Jul 2008
    15
    Default Points along a lwpoly arc
    Hi,
    Firstly I should probably say I am using VBA...
    I have created code which will output coordinates for polylines. This info is then transformed to WGS84 & displayed on google maps.
    My issue is that google maps will not draw curves. I therefore want to split lwpoly curves into segments of a fixed length (say 100mm), and output the coordinates.
    I have the start coords of the arc, the end coords, the bulge. I am able to get the radius, arc length etc, but I'm struggling to determine fixed points along the arc.
    If anyone can help I would be very grateful!
    Thanks
    Toz
    Super Member SEANT's Avatar
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    VBA does not have any direct access to all of AutoCAD’s curve analysis functionality (unlike AutoLisp, VB.NET, etc). There is a third party hook out there; search for Curve.cls and Vlax.cls. That hook, unfortunately, has a couple of problems that may crop up in certain situations.
    It is possible, however, to mimic some of those functions mathematically. For instance, to subdivide a polyline bulge see the attached examples (DWG and XLS).
    Last edited by SEANT; 22nd Aug 2010 at 12:25 pm. Reason: Removed buggy spreadsheet
    Junior Member
    Architecture 2009
    Jul 2008
    15
    Phenomenally useful. Thanks!!
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    The previous spreadsheet had bugs (thanks for bringing those to my attention, tozjerimiah ).
    This newer version should perform better, I hope.
  5. #5
    Junior Member
    Architecture 2009
    Jul 2008
    15
    Quote Originally Posted by SEANT View Post
    Yes it works! Thanks.
  1. Constraint on points, how to get points, axis
    By linnmaster in forum Autodesk Inventor
    Last Post: 22nd Feb 2010, 10:00 pm
  2. low points and high points on a 3d poly
    By iain9876 in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Dec 2009, 12:04 am
  3. Graphing points, scaling the points
    By live4soccer7 in forum AutoCAD General
    Last Post: 25th Jul 2008, 09:44 pm
  4. points
    By yiyan in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2007, 02:12 pm
  5. points in 3d
    By yiyan in forum AutoCAD General
    Last Post: 16th Jan 2007, 02:43 am
