Hi All,
I have a block attribute that is currently set as multi-line text (drawing revision details in a title block). The multi-line text is restricted in its width, however users of the title block insist on putting too much text in the box so that its contents span more lines than the set 'revision details' area allows, so text below is overlapped. Is there any way of locking the maximum size a multi-line attribute can be and not allowing any more text input? Maybe even auto-resize text to fit into a defined area? Any thoughts?
Cheers
Ollie
