Isn't there a DATAEXTRACTION command in 2009? This command extracts data and sends it to a table or an external file such as an Excel spreadsheet.
Hi everyone,
I would like to read a table that would be linked with block attributes. Like a table (either AutoCAD or Excel) of fluids with pressure, temperature, flowrate... that I would link to attributes. I tried to insert a field in the attribute, but what I've found in fields are properties like Color/Layer/Column/Rows ... Anyone could help?
Guiboard
I know about Data extraction, which extracts block attributes into Excel/AutoCAD table. But is the opposite possible? Extracting data from a table into blocks via fields?
Edit: I found it by myself! It had to insert a field; Field category - Object // Field names: Formula. There are 4 buttons: Average/Sum/Count/Cell . Using cell I could pick an AutoCAD table cell.
But I still have 1 question,
Is there a way to link via an Excel table?
hi there
i am also intrested in the same.
i have made a VBA code to import data from excel which can be extended for the required purpose
if you tell me some thing more may be i can help you.Code:Sub markdupfromxl() Dim xlApp As Object Dim xlFileName As String Dim getval(), getval1() As String Dim obj, entRef As AcadBlockReference Dim instPt() As Double Dim a, b As Integer xlFileName = "C:\Documents and Settings\divekark\Desktop\test duplicates.xls" Set xlApp = CreateObject("Excel.Application") xlApp.Visible = False Set xlbook = xlApp.workbooks.Open(xlFileName) Set xlSheet = xlbook.Sheets(1) a = xlSheet.UsedRange.Rows.Count ReDim getval(a), getval1(a) For b = 0 To a - 2 Set myrng = xlSheet.Range("A1") getval(b) = myrng.Offset(b + 1, 0).Value getval1(b) = myrng.Offset(b + 1, 1).Value Set obj = ThisDrawing.HandleToObject(getval(b)) instPt = obj.InsertionPoint Set entRef = ThisDrawing.ModelSpace.InsertBlock(instPt, "flage2", 1#, 1#, 1#, 0) If entRef.HasAttributes Then Dim AttList As Variant ' Build a list of attributes for the current block. AttList = entRef.GetAttributes ' Cycle throught the list of attributes. For j = LBound(AttList) To UBound(AttList) If AttList(j).TagString = "FLAGTEST" Then AttList(j).TextString = getval1(b) End If Next End If Next xlbook.Close xlApp.Quit Set xlbook = Nothing Set xlSheet = Nothing ThisDrawing.Activate End Sub
I had a similar post on this forum, which I got an answer.
http://www.cadtutor.net/forum/showth...data-Via-field
Thanks for the VBA routine, but I've been using an add-on for solving my problem.
