Results 1 to 8 of 8
    Full Member
    AutoCAD not applicable
    Aug 2010
    34
    Default what is chamfer and fillet while drawing rectangle ??
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    I would suggest you try it and find out.
    hint... one makes rounded corners- the other angled
    Full Member
    Aug 2010
    34
    i've tried chamfer, it asks for 1st chamfer distance then second chamfer distance
    and then it asks for the First corner and other corner but i didn't see any difference in the rectangle after it is drawn
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Did you enter any distances for the chamfers? Or did you use the default of 0?
    Try again... then zoom in on a corner
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,135
    Or, if you have entered a large distance for Chamfer, and a large radius for Fillet, draw a larger Rectangle.
  6. #6
    Full Member
    Aug 2010
    34
    seen this figure,
    and the commands are,
    Chamfer/Elevation/Fillet/Thickness/Width/<First corner>: c
    First chamfer distance for rectangles <10.0000>: 100
    Second chamfer distance for rectangles <10.0000>: 200
    Chamfer/Elevation/Fillet/Thickness/Width/<First corner>: 0,0
    Other corner: 5,5
  7. #7
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    your chamfer distance are too large- the rectangle is only 5x5
    try 1 & 2 and see what happens
    Maybe you ought to look in Help for Chamfer to get a better idea of what you're doing.
  8. #8
    Full Member
    Aug 2010
    34
    Quote Originally Posted by lpseifert View Post
    YuP...i understoood
    Thanks
  1. Chamfer & Fillet
    By caddiva in forum Architecture & ADT
    Last Post: 6th May 2010, 02:50 pm
  2. Fillet and Chamfer Help
    By chau in forum AutoCAD Beginners' Area
    Last Post: 2nd Mar 2009, 07:39 pm
  3. Fillet/chamfer on a single line.
    By Robmercury in forum AutoCAD Beginners' Area
    Last Post: 25th Jan 2009, 04:18 pm
  4. fillet,chamfer,2d drawing
    By hahagitugitu in forum AutoCAD Beginners' Area
    Last Post: 12th Oct 2008, 11:36 am
  5. Fillet/Chamfer to Polylines
    By trin_rob in forum AutoCAD General
    Last Post: 26th Jun 2008, 09:13 am
