what is chamfer and fillet while drawing rectangle ??
XuFyan
i've tried chamfer, it asks for 1st chamfer distance then second chamfer distance
and then it asks for the First corner and other corner but i didn't see any difference in the rectangle after it is drawn
seen this figure,
and the commands are,
Chamfer/Elevation/Fillet/Thickness/Width/: c
First chamfer distance for rectangles : 100
Second chamfer distance for rectangles : 200
Chamfer/Elevation/Fillet/Thickness/Width/: 0,0
Other corner: 5,5
your chamfer distance are too large- the rectangle is only 5x5
try 1 & 2 and see what happens
Maybe you ought to look in Help for Chamfer to get a better idea of what you're doing.
