Bart80 Posted August 21, 2010 Share Posted August 21, 2010 How can I scale or stretch a block in one direction? Hope somebody can help me how to fix this. Kind regards, Bart Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 21, 2010 Share Posted August 21, 2010 Insert it with different x-y scales for blocks already inserted, use Properties. Quote Link to comment Share on other sites More sharing options...
Bart80 Posted August 21, 2010 Author Share Posted August 21, 2010 Can you give a sample command? Thank Bart Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 21, 2010 Share Posted August 21, 2010 Hit Ctrl+1 to display Properties (if it isn't already displayed) select the block edit the Scale X in Properties Quote Link to comment Share on other sites More sharing options...
Bart80 Posted August 21, 2010 Author Share Posted August 21, 2010 Hello Ipseifert, Thanks for your answer, but it works not. he scales only one piece of the line and not the hole line. The line shoulde be 1/3 - 1/3 - 1/3 and not 1/2 - 1/4 - 1/4. Hope you a solution for me. Bart Quote Link to comment Share on other sites More sharing options...
cwize Posted October 20, 2010 Share Posted October 20, 2010 Bart80, I wonder if your block is made up of nested blocks. If you draw the item as you show in your example, and make sure "scale uniformly" is NOT checked, you should be able to edit x and y scale as Ipseifert shows. Not sure why this isn't working for you. Quote Link to comment Share on other sites More sharing options...
primalscr33m Posted October 21, 2010 Share Posted October 21, 2010 Give it a linear stretch dynamic attribute, that way you can type in any size you prefer. Quote Link to comment Share on other sites More sharing options...
ica_cici Posted October 22, 2010 Share Posted October 22, 2010 Read this thread, and try the fit.lsp. It works for me. http://www.cadtutor.net/forum/showthread.php?40104-scale-xy Quote Link to comment Share on other sites More sharing options...
