woodman78 Posted August 24, 2010 Share Posted August 24, 2010 Hi, I have a load of lisps setup for doing quantitiy take offs from cross sections. They way I have it setup is that when I pick the material I want to apply to the cross section it creates a new layer for the material. This goes on down through the list. I am wondering if someone could help me with a lisp that would create a table and list all the layers and the total area of hatch on each?? Thanks Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 24, 2010 Share Posted August 24, 2010 Have you tried the built in ._DataExtraction command? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 25, 2010 Share Posted August 25, 2010 Were spoilt we have Advanced road design sitting on top of CIV 3d when we set up a road cross section we can enter all details of all the layers making up the sub base, the volumes report gives totals plus a breakdown volume of each material. I am not sure if civ3d will do the same ? It would be easier than doing cross section by cross section. Just a side issue the volumes calculated using cross sections are not actually 100% accurate if you have curving roads but are generally close enough. Quote Link to comment Share on other sites More sharing options...
woodman78 Posted August 25, 2010 Author Share Posted August 25, 2010 Thanks for the thought rkmcswain but i know the guys in our office and trying to get them to use a single button to plot drawings has proved to be a big deal. I know I have 2 hopes of getting them to go through the data extraction wizard and none of the 2 of them are called "any". Quote Link to comment Share on other sites More sharing options...
