Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    Architectural
    svorgodne's Discipline Details
    lisp developer
    Architectural
    AutoCAD 2013
    May 2007
    Vienna, austria
    83
    Default VLA-object (loop problem) Release 2006
    I may be very stupid for not finding the answer but I was analyzing a lisp routine which contents a function called "vlax-ename->vla-object". I looked for definition in AutoCAD help and found this...
    Transforms an entity to a VLA-object
    Then at the end says see also
    The vlax-vla-object->ename function.
    which says
    Transforms a VLA-object to an AutoLISP entity
    Anyhow I tried to find what a VLA-object is and I found absolutely no answer at all. Can anybody help me please?
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,948
    This is not a silly question at all.
    A VLA-Object is a Visual LISP entity, or collection of such, as part of the ActiveX API (VBA also). You can learn a lot more about VLA-Objects in the Developer help under the "ActiveX and VBA Reference" section.
    I'm sure someone smarter than I will come along, and provide some additional information, but I hope this helps!
    [edit]
    BTW - What is the loop problem you're having?
    [/edit]
    "Potential has a shelf life." - Margaret Atwood
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    To perform many of the VLA/Activex functions on an entity it needs to be made into a vla-object
    for example... to get the Layer property of an entity using VLA
    Code:
    (setq ent (entsel "Select entity: ");select entity
          ename (car ent); get entity name
          obj (vlax-ename->vla-object ename);create vla-object from entity name
          lyr (vlax-get-property obj 'Layer); get Layer property of vla-object
    Civil 3D 2011
    Nov 2009
    3,948
    Quote Originally Posted by lpseifert View Post
    Or one could combine steps, like so:
    Code:
    (setq lyr
           (vla-get-layer
             (vlax-ename->vla-object (car (entsel "\nSelect entity: ")))))
  5. #5
    Civil 3D 2011
    Nov 2009
    3,948
    Likewise, if one needs an ename from a vla-object, this will work:
    Code:
    (setq ename (vlax-vla-object->ename vla-object))
  6. #6
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    Quote Originally Posted by RenderMan View Post
    Code:
    (setq lyr
           (vla-get-layer
    Nit picking, but
    Code:
    (vlax-ename->vla-object nil)
    Lee Mac Programming
    Just another Swamper
  7. #7
    Civil 3D 2011
    Nov 2009
    3,948
    Quote Originally Posted by Lee Mac View Post
    Nit picking, but
    Code:
    LMAO - Yes, of course!
    Funny enough, I typically step through instead of selecting a single entity, like so (thanks Alan!):
    Code:
    (if (setq ss (ssget ...))
        (vlax-for x (setq ss (vla-get-activeselectionset *activeDoc*))
        (vla-delete ss)))
    I'll try to curb my expedited behavior in the future... You'll help make me a "Real [Programmer]" yet.
  8. #8
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,015
    Nit picking, but
    Code:
    x2........
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  9. #9
    Civil 3D 2011
    Nov 2009
    3,948
    Quote Originally Posted by alanjt View Post
    x2........
    I know, I know... You've taught me better, Alan.
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    You guys know each other?
    Lee Mac Programming
  1. idea..loop...problem...
    By scubastu in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Oct 2009, 09:34 pm
  2. Replies: 0
    Last Post: 12th Aug 2008, 08:10 pm
  3. AutoCAD History from Version 1 to Release 2009 Which is the 23rd Release
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 21st Mar 2008, 09:50 pm
  4. how do I enlarge object in AutoCAD 2006
    By dadude in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jul 2006, 03:57 am
  5. OBJECT PROPERTIES CAD 2006
    By benedetta in forum AutoCAD Drawing Management & Output
    Last Post: 28th Mar 2006, 08:26 pm
