Find touching object
manirpg
Dear friends,
I need a lisp for find or select Touching (overlape) objects. Is there any way..........pls help me.
Thanks in advance
Actually I am working in Lighting layout, So i am receving architecture backgrounds, in this drawing more than thousand light fixtures are there,(circle or block) but i cant use this background directly for BOQ(quantity)and layout, because so many objects having more than single.
some places one above the other (i can remove by overkill)
some places not exactly above, slightly mis match (these case i cant use overkill, because i can't deside which one is correct without see)
so i want to select these objects then delete manually.
Please help anyone.
Regards
Mani:)
Hi Alan,
Thanks for ur reply, but FastSel is not exactly what i am searching.........
In this case user have to select any one object, then select all objects.
But my case user dont know where exactly overlaped objects available.
Example: its available around 100 places out of 1000 objects
Thanks
Regards
mani:)
