Richard Radford Posted August 26, 2010 Share Posted August 26, 2010 Hi I have inserted a block into my model which is a base map in DWG format, I imported at X,Y,Z scale 1 and the Block is fine, the block inserts at the right co-ordinates which is great. I prefer to work in mm and the drawing is now in Metres also when i create a viewport on the paper space layout the VP scales are out by 1000. I tried scaling the Model up by 1000 which fixed the issue with mm / m and the scaleing with the VP on paper space, but the base map is now in the wrong place co-ordinates wise? I am from a GIS background and work mostly in ESRI Arcview using shapefiles, and i need the drawing in auto cad to be at the correct Co-ordinates. I tried simply moving the drawing to the right place but its now obviously 1000 times to big. Any help would be much apreciated Regards Richard Quote Link to comment Share on other sites More sharing options...
Tiger Posted August 26, 2010 Share Posted August 26, 2010 IF you bring in a map in meters and scale it up with 1000, and still have the insertionpoint as 0,0,0 the coordinates will be right - but in millimeters. If you bring the map in first and scale it up, you need to have 0,0,0 as your basepoint, then the coordinates will be right - but again, in millimeters. Quote Link to comment Share on other sites More sharing options...
Richard Radford Posted August 26, 2010 Author Share Posted August 26, 2010 Thanks for the fast response That all makes sence thanks, the co-ordinates now display like this 3.3074E+07,4.0992E+07 is this correct? Sorry if i am asking the obvious i af very limited in auto cad knowledge. Richard Quote Link to comment Share on other sites More sharing options...
Tiger Posted August 26, 2010 Share Posted August 26, 2010 If the coordinates are correct or not, I can't say. But if I read the coordinates correct, they are 33 074 000; 40 992 00 in millimeters, so 33 074;40 992 in meters. This is not very obvious at all so don't worry Quote Link to comment Share on other sites More sharing options...
Richard Radford Posted August 26, 2010 Author Share Posted August 26, 2010 Sorted thanks for your help I had somehow convinced myslf that the Co-Ordinates should still be in Meters:lol: Quote Link to comment Share on other sites More sharing options...
Tiger Posted August 26, 2010 Share Posted August 26, 2010 Glad to help Quote Link to comment Share on other sites More sharing options...
