You can do it in Bedit.
I have a bunch of dynamic blocks that need to have the base point moved. How do I do this?
Thanks,
Kent
It must the forest for the trees deal because that's where I'm at and I cant' figure it out for the life of me for some reason.
Start Bedit and select the block you want to edit
Under the Parameters tab of the Block Authoring Palette select Base Point Parameter
Pick where you want the Base point
Close Block Editor w/ Save
You're aware that this will move the block some?
If the block has attributes, you may want to do Attsync
The basepoint marker looks like a fighterplane sight marker circle & crosshairs. Just move it like any other object, or delete and reinsert the basepoint marker.
Also, zoom way out and then back in. The parameter markers will change size in relationship to the zoom level. They will stay big when you zoom back in and you can find them easier. There is a button in the block edit toolbar to resize the markers, but it's only effect is to reduce them back to clean up the display.
Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
Thank you for the replies. I was looking right at the Base Point Parameter on the Pallette and not "Seeing" it. Thank you for helping me "See" it.
Kent
