Results 1 to 2 of 2
Thread: 3d indicator
    Senior Member
    AutoCAD 2008
    Apr 2005
    Oh! Canada
    179
    Default 3d indicator
    I am new user of Inventor (Inv.8 few days ago) and I notice that the UCS
    indicator in Isometric view (pressing F6), the XY plane is in vertical position
    and Z coordinate is pointing toward the user.
    It might be a default..I don't know.
    Can this be change? I want it to be like the default in Autocad (I'm using 2004)
    where the XY plane is in the horizontal position and Z is pointing up.
    I know that there is a rotation command in Inventor but I want it to default same as Autocad.
    Can you tell me. Thank you.
    LSR
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    Hi there i dont think it can be changed, but can i add that in Inventor the UCS indicator is not needed like you use it in autocad.
    In time you wont even look at the Indicator as you will moving around with speed and you will know where you are and what your doing without looking at the UCS
    I suggest Turning OFF the UCS indicator TOOLS>APPLICATION OPTIONS>SKETCH and under Display UNTICK COORDINATE SYSTEM INDICATOR
    Even if you are new to Inventor, after 2 days learning the USC could be turned OFF.
    You keep control from the sketch to the model and from the model you know what plane your on because you rotate the model and select a plane to sketch on.
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
