Results 1 to 6 of 6
    Full Member mikman's Avatar
    mikman's Computer Details
    HP Compaq
    View Sonic 22"
    Civil
    mikman's Discipline Details
    Design Technician, CAD Department
    Civil
    We work primarily in Civil Airport Design
    Civil 3D 2012
    Jun 2008
    Scottsdale, Arizona USA
    30
    Question RTEXT Plotting Issue
    Hi all,
    I am currently operating in Autocad 2004 and LDD 2004. We use RTEXT in lieu of the plot stamp to display the drawing name, file path, date, etc. When I plot from plain CAD it plots just fine, but when I plot from LDD all I get is a box with an "X" through it. I assume its a file setting that is turned off or a support file that is not loaded, but am unable to determine what it is to enable plotting of the RTEXT. Other machines in our office have had this same issue and we are still stumped on them too.
    Any thoughts?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    This from the Help files of Express Tools
    Note:
    If a drawing with an RText object is opened on a computer that does not have RTEXT installed, the proxy object that results displays the bounding box of the RText object. If you plan to send your drawing to someone who does not have RTEXT, you can explode the RText objects to MText objects with the EXPLODE command.
    Perhaps you should load Express Tools into LDD
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Rtext is an Express tool, be sure the Express Tools are loaded in your installation of LDD.
    <too slow>
    HP Compaq
    View Sonic 22"
    Civil
    Civil
    Civil 3D 2012
    Jun 2008
    30
    The express tools are loaded and I use them regularly in LDD, is what is the most confusing. I just had LDD reinstalled about two weeks ago and had the express tools reinstalled then. Is there an update to Express tools that should be downloaded?
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    OK, just trying to explore different avenues - Have you tried to use Rtext in LDD?
    I know you can use other Express Tools in LDD, but sometimes strange things happen
  6. #6
    HP Compaq
    View Sonic 22"
    Civil
    Civil
    Civil 3D 2012
    Jun 2008
    30
    So I went back to LDD and tried from the start to create a new RTEXT and now it all works. I don't know what happened but thanks!
  1. AutoCAD 2010 plotting issue
    By ascen707 in forum AutoCAD General
    Last Post: 8th Oct 2009, 01:38 pm
  2. Plotting issue - cpc files
    By ANDY0871 in forum AutoCAD General
    Last Post: 22nd Jan 2009, 06:44 pm
  3. VB plotting issue
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Dec 2007, 07:21 pm
  4. PDF Plotting Issue
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 10th Sep 2007, 10:19 pm
  5. Wireframe plotting Issue
    By koruiwake in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Mar 2006, 05:52 pm
