Hippe013 Posted August 30, 2010 Share Posted August 30, 2010 Hello Everyone I have a question about the Vlide settings. I had it (at one time) where when vlide encountered an error it would tell me what the error was. I must have switched somthing and now it doesn't tell me what the error was. It just quits evaluating. Does anyone know what setting I need to be looking at? Thanks in advance hippe013 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 30, 2010 Share Posted August 30, 2010 Sounds like the *error* handler has been overridden. Type: (setq *error* nil) at the command line and see if the problem persists. Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted August 30, 2010 Author Share Posted August 30, 2010 Thank you! Thank you! Thank you! Thats exactly what it was! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 30, 2010 Share Posted August 30, 2010 Thats exactly what it was! I'm glad However it is worrying that it was the cause, as this means you are running a badly written program in which the error handler has been redefined and not reset or localised. Lee Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted August 30, 2010 Author Share Posted August 30, 2010 You are right... and I believe I know where the culprit is... I will have to double check the function collection that I use. Thanks for the heads up Quote Link to comment Share on other sites More sharing options...
