muck Posted August 31, 2010 Share Posted August 31, 2010 I have created a new profile and exported it to a file. I want to make a short cut to that profile but I do not know where to put the profile file so AutoCAD will see it. Does anyone know where to put profile files? Thank you, Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 31, 2010 Share Posted August 31, 2010 As long as you add the /p startup switch to the shortcut properties of the program's Windows desktop icon and include the path to the .ARG file AutoCAD should load it. Quote Link to comment Share on other sites More sharing options...
muck Posted August 31, 2010 Author Share Posted August 31, 2010 Does the file need to be in a AutoCAD support folder? How does the /p tell it where to read the file? Thank you, Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 31, 2010 Share Posted August 31, 2010 There are a dozen or so startup switches that AutoCAD supports. My guess is the /p just tells AutoCAD it will be working with the profile who's path is provided in the shortcut properties and not the default profile normally loads. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 31, 2010 Share Posted August 31, 2010 A search of the AutoDesk website using the criteria startup switch brought up the following link: http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=2894625&siteID=123112 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 14, 2010 Share Posted September 14, 2010 If you copy your autocad desktop icon and click softly then right button click go to properties you can view and edit the startup autocad command so you could have a profile with /p civil or /p acad as an example. We have a notebook 2011 plays up when connect/disconnect network, we eventaully got it to work with two profiles named network and home pretty obvious which one to use. Quote Link to comment Share on other sites More sharing options...
