Auto Selecting Text
caltes75
Hey all. I am new to writing .lisp routines and this is my first post. I am having an issue with a version of txt2mtxt routine. I want to be able to run the below listed routine without manually selecting the text. I want it all to be automated. Is this even possible or am I completely out there.:? Here is the code that I have so far.
(defun Merge()
(if (and (setq ss (ssget '((0 . "MTEXT,TEXT")))) ;Select both MText & DText
(> (sslength ss) 1) ;Check if more than one selected
) ;_ end of and
(setq n 1 ;Initialize counter
en (ssname ss 0) ;Get 1st selected
ed (entget en) ;Get its DXF data
txt (cdr (assoc 1 ed)) ;Get its textvalue
) ;_ end of setq
(if (= (cdr (assoc 0 ed)) "TEXT") ;If the 1st is a DText
(command "txt2mtxt" en "") ;Convert it to a MText
(setq obj (vlax-ename->vla-object (entlast)))
(vlax-put-property obj 'LineSpacingFactor 1)
(vlax-put-property obj 'LineSpacingDistance 0.25)
(vlax-put-property obj 'LineSpacingStyle 2)
(setq en (entlast)) ;Get the new MText
) ;_ end of progn
) ;_ end of if
(setq eo (vlax-ename->vla-object en)) ;Get the ActiveX object of the 1st text
(while (
(setq en (ssname ss n) ;Get the nth text
) ;_ end of set
(setq txt (strcat txt "\\P" (cdr (assoc 1 ed)))) ;Append its string to add to the 1st text
(entdel en) ;Delete the nth text
(setq n (1+ n)) ;Increment the counter
) ;_ end of while
(vla-put-TextString eo txt) ;Modify the 1st text to the concatenated string
(command "_.justifytext" pause "" "ML")
) ;_ end of progn
) ;_ end of if
You might also consider these:
  • foreach, if not vlax-for
  • vla-delete
  • vla-get-textstring
  • vla-put-attachmentpoint
  • vla-put-linespacingfactor
  • vla-put-linespacingdistance
  • vla-put-linespacingstyle
Also, be sure to delete your selection set toward the end of your routine:
(vla-delete ss)
you'll need (setq ss (ssget "_x" '((0 . "mtext,text"))))
EXAMPLE will return T
(wcmatch (strcase "hi old text!") "*OLD TEXT*")
use entmod
what is the purpose of using entmod? :unsure:
Modifies the definition data of an object (entity)
See VLIDE Help for more information.
create a few texts with the word old in it.
;;method by Alanj
;;modified by reid b.
(defun c:test (/ ss id ent a b)
 (setq ss (ssget "_x" '((0 . "text,mtext")))
         id 0)
      (while (setq ent (ssname ss id))
        (if (wcmatch (strcase (cdr (setq a (assoc 1 (setq b (entget ent)))))) "*[color=red]OLD[/color]*")
[u];;[color=red]OLD[/color] must be uppercase[/u]
[color=dimgray][color=black][u];;will only modify text with the word [color=red]old[/color] in it[/u][/color]
[/color]           (entmod (subst (cons 1 "[color=red]NEW[/color]") a b))
      (setq id (1+ id))
Edited by Lt Dan's legs
(defun c:test ( / old new )
 ;; © Lee Mac 2010
 (setq old "Lee" new "Mac")
   (lambda ( s i / e )
     (if s
       (while (setq e (ssname s (setq i (1+ i))))
         (entupd
           (cdr
             (assoc -1
               (entmod
                 (subst
                   (cons 1 new) (assoc 1 (entget e)) (entget e)
   (ssget "_X" (list (cons 0 "TEXT,MTEXT") (cons 1 old))) -1
^^ Much easier :)
(defun c:Test (/ new old ss)
 (setq new "WoO"
       old "Hoo"
 (if (setq ss (ssget "_X" '((0 . "MTEXT,TEXT"))))
   ((lambda (i / e s l)
      (while (setq e (ssname ss (setq i (1+ i))))
        (if (wcmatch (strcase (cdr (setq s (assoc 1 (setq l (entget e)))))) (strcase old))
          (entmod (subst (cons 1 new) s l))
     -1
to Lee,
Seems your code will only change Lee as it's writen. If it's all caps or lower case the text will not change. Wouldn't this be the same as using
(ssget "_x" '((1 . "Lee"))) then entmod?
to Lee' date='
Yeah, I'll confess I didn't read the whole thread and didn't know that case sensitivity was an issue...
