Results 1 to 6 of 6
    Junior Member
    Civil 3D 2009
    Feb 2010
    10
    Default autocad land desktop 2009
    hello i´ve imported a topografic list of points to tha land software...i´ve treated the data created lines and stuff... and i make the level lines....but they dont respect my break lines, so the level lines cross them over and over again.
    how can i fix this error?
    withe the civil3d i cant even import the points corrcetly cause they get in with other coordinates that are not the real ones, or the ones in the txt file, plus its a new software for me that i cant even create the level lines.
    so i really need help creating the level lines without crossing the defined breaklines that i chose in the drawing. if someone can help me here it goes also my email: tgp.topografia@gmail.com
    i hope that soemeone can resolve this problem for me.
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    In Civil 3D Land Desktop Companion 2009 you have access to the Terrain menu... look at the Edit Surface sub-menu for some helpful tools.
    Hope this helps!
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,572
    Quote Originally Posted by ManAtWork View Post
    Let's stop there and figure out why it isn't respecting your break lines...
    Did you add them as break lines to the surface before building?
    Did you verify that they were added properly, that they have an elevation, etc.?
    ...also my email: tgp.topografia@gmail.com
    Make sure you subscribe to the thread with email notifications enabled.
    R.K. McSwain
    CAD Panacea | twitter
    Senior Member
    AutoCAD 2010
    Aug 2009
    Baltimore, MD
    111
    If your linework has valid elevations then on the prospector, under your "SurfaceName", under Definition select Drawing Objects; Add; ObjectType: Lines.
    If your linework is 2D then under Defintions, Select Breaklines; Add;Type: Proximity
  5. #5
    Senior Member
    Civil 3D 2011
    Jul 2008
    Colorado
    247
    Quote Originally Posted by KJB View Post
    These instructions are for Civil 3D. In Land Desktop, there is no Prospector, and surfaces are created in Terrain Model Explorer.
    Just thought I should mention that, before things got too confusing...
    Richard 'Sinc' Sincovec
    Manager of Technology - Edward-James Surveying
    Tools for Civil 3D - Quux Software
  6. #6
    Senior Member
    AutoCAD 2010
    Aug 2009
    Baltimore, MD
    111
    Opps. Saw Civil 3D 2009 under the profile name and responded incorrectly. You can still add 3D drawing objects or 2D proximity breaklines in Terrain Model Explorer.
  1. Land desktop 2009 import points
    By pgodinho in forum Civil 3D & LDD
    Last Post: 24th Aug 2009, 03:05 pm
  2. Land Desktop Companion 2009
    By dragaonortenho in forum Civil 3D & LDD
    Last Post: 5th Mar 2009, 04:37 pm
  3. Creating mesh in Autocad land desktop
    By Cybro in forum Civil 3D & LDD
    Last Post: 28th Jul 2008, 06:19 pm
  4. land desktop vs autoCAD
    By Jfennell in forum AutoCAD Beginners' Area
    Last Post: 22nd May 2008, 05:03 pm
  5. AutoCAD 2004 Land Desktop Contours at wrong elevation
    By Hardney in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2006, 08:50 pm
