Text to Mtext conversion using lisp previous selection set? (COMMAND " txt2mtxt s1")?
muck
Is there a way to use lisp to convert text to mtext? Using (COMMAND " txt2mtxt") will not
work. I would like to use lisp to start txt2mtxt text to mtext converter then use a previous selection set from another
lisp routine. In this case s1 is my previous selection set. I thought (COMMAND " txt2mtxt" s1)
might do it but it does not.
Thank you,
