Take a look at: http://tinyurl.com/ayngb
Hi. I have be using ref edit and have noticed that sometimes I cannot use this command because when I try this message come up "**Object reference missing:AcDbRasterImage to AcDbRaster ImageDef." Has anyone else had this problem? Is there a way to have find these missing object references and solve this problem so I can us the ref edit command?
Thanks!
I had a sim prob, but not the same message. There is a lsp from Hyposmurf that fixed my Ref Edit problem
[url]http://www.cadtutor.net/forum/viewtopic.php?t=2373&highlight=
From the "List of Weird Things That Only Happen to Greg"
When you have raster image embedded in xref or block, you can't use refedit to edit. This is because AutoCAD cannot edit raster image directly, but can only change the brightness, constrast and fade setting. The only way to actually edit it would be to take out the raster image.
Awesome,
Thanks for the insight. I assume that is for klowbers message.
What does the error "Object reference missing: AcDbLayerTableRecord, to AcDbPlaceHolder. " mean?
